Help
Old Aug 20, 2011 | 03:36 PM
jd23's Avatar
Default Help
I got a 91 crx si put newhead on drove it for a while. Was going down the road and it bogged dies slow.Had my buddy tow it to his garage he charges the battery abd it crank.when i was driving home 2 miles for my house it done it again died but slow like it was losing power. when i got it back to my house it cranked was halling *** while idling,Now it just clicks no gas is spitting out
Old Aug 20, 2011 | 03:41 PM
91efbluehatch's Avatar
Default Re: Help
im confused?
Old Aug 20, 2011 | 03:51 PM
jd23's Avatar
Default Re: Help
i ordered a starter alternator and msd distributor im gonna try to narrow it down my homeboy told me to check some kind of relay
Old Aug 20, 2011 | 03:54 PM
jd23's Avatar
Default Re: Help
when it dies i got to shift to 4th then 3rd and so on then it dies if a piston ring was blowed what would it do idone a compression check it read 200 on all cyllinders
Old Aug 20, 2011 | 04:09 PM
Default Re: Help
if a piston ring blew you wouldnt have healthy compression numbers.
also you need to put a specific title. like "HELP- CAR RANDOMLY DIES" or something like that.
and you also need to specify what motor.
Old Aug 20, 2011 | 04:46 PM
jd23's Avatar
Default Re: Help
My bad im new to this its a d16 the only thing i done wrong when I put the head on I never put a intake gasket on it.
Old Aug 20, 2011 | 04:52 PM
claymonthug's Avatar
Default Re: Help
probably just didnt tighten the 10mm down on the alternator when you put the head on.
Old Aug 20, 2011 | 05:11 PM
jd23's Avatar
Default Re: Help
Thanks. Can u pull the fuel pump out from the back like a 92 hatch or am i gonna have to drop the tank.
Old Aug 20, 2011 | 05:17 PM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
Default Re: Help
so you are running it with no intake gasket?
Old Aug 20, 2011 | 06:02 PM
jd23's Avatar
Default Re: Help
I put the intake gasket waiting on some new headers a msd distributor alternator and starter.SO I cant crank it yet. It runs when it dies it dont die suddenlly its like its losing power.
Rainville
Apr 12, 2006 03:16 PM
Lightweight Boost
Mar 21, 2006 09:12 AM
Stick2shiFTN
Oct 12, 2005 12:14 PM
91civicEX
15
Feb 1, 2004 06:14 PM
ef9one6
Sep 19, 2003 01:34 PM
