vtec problem b16a
Old Aug 20, 2011 | 11:10 AM
Beasting EF22's Avatar
Default vtec problem b16a
i have a b16a in a obd0 ef with obd0 b16a 5 speed ecu. but for some odd reason my car is redlining at 7200 and the vtec is not engaging. I have taken the solenoid off and check it yes it clicks likes its suppose to so i clean the filter and put it all back together, take her for a drive and bam same **** 7200....any help please. getting pissed off
Also my ecu is throwing code 21. which has to do with the solenoid. lmk something
Old Aug 20, 2011 | 11:17 AM
claymonthug's Avatar
Default Re: vtec problem b16a
did you do the swap? did vtec ever work? did you do the wiring?
Old Aug 20, 2011 | 11:22 AM
i have rechecked all the wiring and its all correct..weird thing about it is sometimes it will redline at 8200 how its suppose.
and since i have had it vtec does not work, but the car had a single cam ecu hook up when i bought it and i put the pr3 obd0 in and it runs fine. just no vtec
Old Aug 20, 2011 | 11:24 AM
Pin A8 on your ecu is the only pin that pertains to that specific code.
code 22 would be the pressure switch at pin B5.
first check your connections, the solenoid itself might be malfunctioning. depending on what kind of tools you have the second thing you may want to do is pick up a solenoid from an ex civic at the junk yard
Old Aug 20, 2011 | 11:26 AM
hmmm does the solenoid have one or two plugs on it? id re run both the wires if you got it swapped than report
Old Aug 20, 2011 | 11:32 AM
yeah i know the solenoid plugs into a8 but there is something plugged into it already should i run my own wire from the vtec noid and splice into the one in a8 as well to have them both connected?
and i know its not the noid i took it off last night and ran it to the battery it click everytime
Old Aug 20, 2011 | 11:37 AM
to the solenoid there is the only plug up top that is green, then on the bottom plug there is the two wires
Old Aug 20, 2011 | 11:40 AM
take a pic of the two wire plug if you can. its on the pressure switch one of the wires is a ground and one goes to B5
Old Aug 20, 2011 | 11:48 AM
there really isnt a common vtec problem thats not easy to spot. its your solenoid, oil pressure/ passages, wiring, ecu, and iv heard of them not engaging due to faulty lmas. never in person tho. it could be part of a bigger timing problem i guess?
Old Aug 20, 2011 | 11:51 AM
im at work right now but as soon as i get off i can take a pic and send it to you,
phone number to send it too?
And im gunna check all the grounds again for the fourth time and make sure there perfect.
Also another question people are telling me that obd0 cant run vtec which is bs cause they wouldnt make the ecu, but there telling me to change the ecu and dizzy over to obd1 and it will fix it ?? i want it to work without switching it.
thanks for your help btw
Old Aug 20, 2011 | 12:05 PM
mathewb20's Avatar
How about you post a picture here so more people can help you. A lot of vtec problems are because of wiring or wrong ecu, The pressure switch has 2 wires, one going to the ecu, and one ground. the solenoid itself has one wire going to the ecu. Find the pinout on your ecu and run the 2 wires straight. and the ground run to the bolt to your solenoid.
Old Aug 20, 2011 | 12:46 PM
what the color wire that is suppose to be plugged into pin a8 ???
Old Aug 20, 2011 | 12:58 PM
your right it is bs. obd0 vtec does definitely exist. i definitely suggest running your own wires. take a pic of the engine code, the vtec plug, and the wiring/ plugs at your ecu and post them on this thread. this is all the info and pic you should need to get your wiring figured out.
A8 VTEC solenoid
B5 VTEC oil pressure switch
1. on the two wire plug (green in the picture) you can ground that out to pretty much any bolt under the hood. i grounded mine out to a bolt that attaches the solenoid to the head.
2. on the two wire plug (orange in the picture) run that to pin b5
3. single green wire coming out of solenoid goes to a8
***TIP OF THE DAY: trying to figure out wiring on cars with engine swaps is generally a losing battle. just run new wires yourself or have someone who knows what they are doing run wires
picture reference taken from http://ef-honda.com/ben/EFwiring.php
Old Aug 20, 2011 | 01:15 PM
apparently you might need this too. but id say if you dont know how to read plugs you probably shouldnt be running wires. but heres the info anyway.
HOW TO COUNT PINS
Old Aug 21, 2011 | 07:30 AM
From reading all the post and previous swaps i know how to do the wiring but the thing that i don't get is my a8 pin is not empty it has a yellow wire going to it.
I'm going to take pics right now be right back to post them.
I lost last night simply because i didn't have vtec i was right on the people i ran bumpers with vtec i would have left em
Old Aug 21, 2011 | 07:44 AM
so my phone died in the middle of taking pics but the cord that is plugged into a8 is yellow with brown dots? should i just splice into that one just to see if the vtec kicks in and then run it the right way ?
Old Aug 21, 2011 | 08:26 AM
Old Aug 21, 2011 | 08:30 AM
let me know if you need any other pics im seriously gonna figure this **** out...thanks for all your help. i appreciate it..
Old Aug 21, 2011 | 02:24 PM
clip that yellow wire at a8 BUT LEAVE ENOUGH WIRE TO STRIP IT AND ATTACH ANOTHER WIRE. run a wire from the ECU pin A8 to the single wire coming off the solenoid. drive car. report.
(the yellow wire used to go to something else "lock up solenoid" but it doesnt matter anymore)
Old Aug 21, 2011 | 04:28 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
A8 is for Lock-up Solenoid and pertains to automatic transmissions only. On a PR3 or PW0 ECU it is for the VTEC Solenoid... do as the above poster said.
Old Aug 21, 2011 | 05:22 PM
blank879's Avatar
Its me Beastingef on my friends account.
the yellow wire (with brown) runs to the fuels pump, at least thats what we think because there isnt any other wire of that color in the car, only from ecu and from fuel pump.
but vtec works hooking it up as said. running awesome
now there is a new problem..
have the car running perfect, ran it a few times from a dig and roll. park car. sits a few minutes and wont start back up.
upon ignition the dash lights only flash on then cut off quickly. the car wont crank at all and loses all power, including fan. so we redo all ground on car, sand down etc. we tried starting the car right from the starter, we tried push starting.. nothing.
btw the windows wont roll up but theres still power (lights work)
wtfff
Old Aug 23, 2011 | 07:00 AM
So after having no power for two whole days we figured it out, happened to be the alarm was shorting out the whole car.
Thanks for all your help guys.
Old Aug 23, 2011 | 02:33 PM
no problem. glad to healp. if that problem happens again check your main relay
Beasting EF22
Aug 20, 2011 11:21 AM
RB_EJ8
Aug 6, 2008 03:56 PM
Rywire
Dec 27, 2002 12:30 PM
flat-blk-HB
Oct 5, 2002 09:28 AM
