LS/Vtec in a VW Manx Buggy.....WIRE HELP!
Old Aug 19, 2011 | 01:28 PM
HondaManx619's Avatar
Icon2 LS/Vtec in a VW Manx Buggy.....WIRE HELP!
I need some help here guys. I have been to like 4 forums and no one knows the wires, vacuums and sensors req'd for good running performance in an LS/Vtec.
The thing is, We put this motor in a buggy and wanted to eliminate all of the wires possible, only connect the vacuums needed, and same with sensors.
Does anyone here have any ideas? At this point we have almost everything hooked up except vacuums and we have a rough idle and she farts when we throttle it. (I know thats not very technical, but I dont know what else to say it revs a little but sounds like too much air maybe?)
Anyway, there are 3 videos on youtube linked to my buggy build site, :
http://www.hondamanx.ucoz.com
Thanks in advance!
Hondamanx619
Old Aug 19, 2011 | 03:26 PM
Blown90hatcH's Avatar
Default Re: LS/Vtec in a VW Manx Buggy.....WIRE HELP!
Awesome man. I build harnesses for guys doing just this. Best thing I can recommend is wiring up your ecu so that you can run a check engine light. This way you can see what codes the ecu is throwing. Here is an older picture of what I normally do for buggy guys.
What ecu are you running?
Old Aug 19, 2011 | 05:33 PM
Thanks. Yeah, I have it wired with a toggle to a dash light so when I need to check it I can sitting in the car.
Old Aug 19, 2011 | 05:43 PM
So is it throwing any codes? What ecu?
Old Aug 19, 2011 | 05:48 PM
I haven't looked at codes yet as we have only started it a couple times and I dont want to let it run sounding like this(watch the videos on the website and you can hear it)I just want to know if I plug vac's and eliminate sensors and wires will it run normally?
I got a PM from someone already who reminded me to check out the FPR vac.....might be on to something there. I will check codes next shop day and repost codes. should be a day or so. Thanks!!!
P28 ECU sorry.....
Old Aug 19, 2011 | 05:53 PM
Running with no vac lines on it shouldn't make it back fire like that. See if you have the TPS and MAP sensor connectors switched. Is that P28 ecu chipped?
ILOVEMYHONDA206
May 18, 2008 01:26 AM
crispchris
Jun 29, 2007 12:33 PM
egturbo1
Aug 10, 2006 12:53 PM
torr
Apr 21, 2003 07:33 PM
Jefe06
Oct 3, 2001 07:47 PM
