How do I remove the bottom alterntor bolt on a 90 CRX????
Old Aug 19, 2011 | 12:16 PM
r90crxhf's Avatar
Icon2 How do I remove the bottom alterntor bolt on a 90 CRX????
Everyother bolt seems to of come out fine.. except for the LONGASS bottom bolt under the altrnator. For some strange reason the head on this bolt is a square??? I have no wrench socket for this bitch Ive tried hitting it with a hammer..BUT this altrnator is still the factory one, wich means its been on there for 20 ****in years :/.... anyways does anyon have a better idea on how to wack the sucka out?!?!?!
Old Aug 19, 2011 | 12:25 PM
Tyson's Avatar
Default Re: How do I remove the bottom alterntor bolt on a 90 CRX????
other side buddy.
Old Aug 19, 2011 | 12:31 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Originally Posted by Tyson
other side buddy.
That made me chuckle... OP you the bolt comes OUT the side the square head is on...
Old Aug 19, 2011 | 12:36 PM
r90crxhf's Avatar
yeeeeaaaah.. Im not hitting the side with the square head... Im hitting the side where the nutt bolt was removed! ;0 but this **** is so old that the ****ing side where the nutt bolt gos is getting damaged by the hammer hits :/
Old Aug 19, 2011 | 12:45 PM
DO IT ON ALL FOURS
Reading PWNs you... it specifically says "For some strange reason the head on this bolt is a square??? I have no wrench socket for this..." if you looked there is a tab that won't allow the bolt to turn anyways...
The best options would be: rock the alternator back and forth spraying penetrating fluid as you go, heat the bolt and alternate with the afore mentioned method, or break the alternator housing and cut the bolt out... haha. At this point I can assure you - unless you have a die to fix the threads you most likely need a new bolt now anyways...
Old Aug 19, 2011 | 04:24 PM
///Mathew's Avatar
Lol...nutt bolt. Twice. Lol.
87CRX
Aug 30, 2008 05:59 AM
Cashieboi
Oct 9, 2006 08:17 PM
spidermancivic
Oct 5, 2006 10:10 PM
spidermancivic
Oct 3, 2006 09:41 PM
is3oo
Oct 4, 2003 01:48 PM
