Car will not start and other issues
Old Aug 19, 2011 | 06:00 AM
ivey_usmc's Avatar
Icon3 Car will not start and other issues
Can someone pm me thier number I need some serious help. I need someone that knows the f22b1 inside and out! I got to have my car up ASAP!!!
Thanks -Josh
Old Aug 19, 2011 | 08:16 AM
ivey_usmc's Avatar
Default Re: Car will not start and other issues
Well no ones pmed so here is the first issue. I installed a new head gasket and t-belt and the car will turn over just fine but will not catch at all? It doesent even want to start to catch. I am getting spark and fuel. I have triple checked all conections and plugs. What else could it be?
Old Aug 19, 2011 | 10:30 AM
bdmlilburn's Avatar
well i would guess your timing is off or you left something unplugged. is the engine making any weird metal noises when you turn it over?
how did you check for fuel and spark?
did you unplug the battery before you started doing anything? check all the fuses even if you did
Old Aug 20, 2011 | 06:55 AM
poorman212's Avatar
What year is this?
If a 4th gen, did you happen to remove the t-stat and forget the ground?
Old Aug 20, 2011 | 07:13 AM
exb18c1's Avatar
If you have spark and fuel the things amiss are compression and timing. You have to recheck timing marks and compression to begin with.
Old Aug 20, 2011 | 07:18 AM
ivey_usmc's Avatar
Originally Posted by poorman212
What year is this?
Its a 96 EX Ground off the tstat? Where?
Old Aug 20, 2011 | 07:37 AM
poorman212's Avatar
on the 96 (5th gen) the ground in on the TB.
Old Aug 20, 2011 | 07:52 AM
ivey_usmc's Avatar
yea that is on
Old Aug 20, 2011 | 08:09 AM
poorman212's Avatar
Can you pull the upper t-belt cover and recheck the timing? Also make sure the the dist rotor is pointing to #1 wire on the cap.
From there you might rent/borrow or use a compression tester.
Old Aug 20, 2011 | 08:21 AM
ivey_usmc's Avatar
[QUOTE=poorman212;45873010] Also make sure the the dist rotor is pointing to #1 wire on the cap.
QUOTE]
if its not do I just pull the distributor and turn the end the other way?
Old Aug 20, 2011 | 08:51 AM
poorman212's Avatar
Yes, if you pulled it during the head change and that....it is hard to do but the dist can be forced into place 180* out. So if you line up the marks on the timing (cam right, crank right) and the rotor is pointing wrong (180 the "other" way-I think that would be towards #4 cyl).
Old Aug 20, 2011 | 09:03 AM
ivey_usmc's Avatar
Ok thanks! Ill check that when I get off from work today. Can the cam cover come off with out pulling things apart to check TDC?
Old Aug 20, 2011 | 09:47 AM
poorman212's Avatar
Yes, might need to remove the valve cover.
dcomer04
May 14, 2008 07:50 AM
-Gambit-
Nov 13, 2005 05:38 PM
speedracer9k
Mar 29, 2004 03:15 PM
fluffy
18
Nov 8, 2002 05:10 AM
