H22A7 main cap issue
Old Aug 19, 2011 | 04:36 AM
eTiLiKo's Avatar
Default H22A7 main cap issue
I'll try to make the story short. I built a good number of Honda, Mitsu, Nissan etc. engines in the last few years.
The subject of this issue is a BRAND NEW H22A7 short block. NEW from honda dealer, bought at a very good price because it was in the depot for years.
I have disassembled it to check everything, clean all the OEM grease in it and lubricate. All the things concerning main bearings and cranck was OK.
I started to reassemble it, using for reference the USDM 1993 Prelude service manual. Oiled the bolt threads (I have reused the old bolts), put a good amount of redline assembly lube on bearings, and tightened at 55lb-ft in order.
Surprise, the cranck doesn't turn free! I have made some other attempt, and found that if I tighten the 5th main cap (the smallest) less than the others the cranck turns free! The good tightening torque seems to be 52ft-lb for 1st to 4th caps and 48ft-lb for the 5th main cap.
This doesn't make sense to me.
Anyone of the reputable engine builders in HT has ever seen something like this on a H22?
Old Aug 19, 2011 | 04:44 AM
DDTECH's Avatar
Default Re: H22A7 main cap issue
You should do a rotation of the crank after each cap is tighten down.
Go back and disassemble and start over. When you tight down each cap.. you need to make a full rotation of the crank.. when you can't move it anymore, you've found your problem.
From there you can tell if you need to change bearing clearences or what not.
Old Aug 19, 2011 | 04:54 AM
eTiLiKo's Avatar
I have already tried to rotate, and the problem is on the last cap, the 5th, the smallest. The bearing clearance on this cap is already on the large side, it's 0.030mm when honda spec is 0.009-0.033mm.
Old Aug 19, 2011 | 06:23 AM
DDTECH's Avatar
go to .033
Old Aug 19, 2011 | 02:59 PM
eTiLiKo's Avatar
0.003mm is...nothing, I have to do a little math to see if it's possible.
Tomorrow I'll check if the cranck is straight on the main, but it's a BRAND NEW cranck!
Old Aug 23, 2011 | 04:31 AM
eTiLiKo's Avatar
The cranck runout is OK, measured on the center journal with the cranck supported on outer journals, it is 0.02mm.
journal taper and out of bore is OK.
I have tried to measure main caps distortion without main bearings. It is 0.02mm with mains torqued to spec. To minimize distortion I have to torque the mains to 60Nm (44 ft-lbs).
IT IS A BRAND NEW cylinder block, how it is possible???
The only block mod is a kaizenspeed balancer shaft removal kit.
Old Aug 23, 2011 | 04:42 AM
DDTECH's Avatar
I'd have a machine shop go back and line hone everything and make sure everything is on point.. You're only going to be able to do so much without a machine.
casting tolerences?? I dont know.. but i wouldn't proceed any futher until something is machine measured.
Old Aug 23, 2011 | 07:55 AM
eTiLiKo's Avatar
Anyone else have seen main cap distortion on a fully functional H22 cylinder block?
Old Aug 23, 2011 | 11:31 AM
dc4teg's Avatar
I had a issue like this but it was not on the main caps, it was on the cam caps. I took it to a machine shop and end up having to get a new head. Something was outta spec with the cap closest to the timing belt. They couldnt line bore it for some reason. That kinda thing is annoying to deal with because you cant see the problem with your eyes. Please if you figure this out let us know because I have an h2b so I like to get knowledge of things like this.
Old Aug 24, 2011 | 03:33 AM
eTiLiKo's Avatar
I'll update for sure.
But my case is very different from your. I can see everything because I build engines from years. I have many torque wrenches, digital mic, bore gauge, dial indicators, plastigauge, etc. etc.
I have taken more measure : to have an acceptable balance between caps distortion and caps load I'll have to torque the 2nd and 5th caps, the smallest, at 60Nm (44ftlbs) and the others to 70Nm (52ftlbs).
If someone on this board have built a lot of H22 engines, maybe have encountered this problem...
Old Aug 24, 2011 | 03:53 PM
PyroProblem's Avatar
Just for ***** and giggles, what would happen if you swapped the crank around 180 and re-torqued the main caps?
Put the nose of the crank where the flywheel would go, and the flywheel side where the ol pump would go...
Perhaps this will help pinpoint if its the block's mains that are out, or the crankshaft...
Old Aug 25, 2011 | 06:27 PM
EG1834's Avatar
At which cap are the thrust bearings?
Old Aug 25, 2011 | 06:50 PM
I think #4
Old Aug 26, 2011 | 02:53 PM
xzodiackillerx's Avatar
is the cap on the right way? I know its a dumb question but it wouldn't hurt to check
Old Aug 27, 2011 | 04:24 AM
eTiLiKo's Avatar
Ehehehe, it's in the right way, yes. All the normal checks have been made and not show abnormalities.
The thrust bearings on the H22 is on one of the biggest caps, the #4 if I remember correct.
stv310
Feb 24, 2018 11:25 PM
vtecn8ive
Sep 13, 2006 04:36 PM
na200whp
Nov 1, 2004 08:22 PM
no_one_
Nov 11, 2003 11:36 AM
