Transmission & Drivetrain Gearboxes, Differentials, Clutches
Smog checks and transmission gearing.
Old Aug 18, 2011 | 06:34 PM
gablagloire's Avatar
Default Smog checks and transmission gearing.
The California smog check goes by 15 Mph and 25 Mph tests to determine the levels of smog.
What if second gear was swapped out in favor of lower RPMs to help pass?
Would it be possible if someone could find the sweet spot on their engine, then swap out the gear to pass.
I have a BARD car, so im not looking to cheat anything. Having a debate with a friend.
Old Aug 19, 2011 | 07:21 AM
leanmeanb18's Avatar
Default Re: Smog checks and transmission gearing.
Its all the chud dude get sum seafoam and that will clean yur chud!
Old Aug 19, 2011 | 09:37 PM
flush_EJ1's Avatar
Its not the speed that gets you. Its the load. Its higher on the ASM15/50 to test the NOX emissions generated from climbing a hill and lower on the ASM25/25 to simulate highway driving HC/CO.
There is also a minimum RPM the vehicle must be at to test. If its too much different it also sets a red flag in the system(but that's more of an issue for the tech). Its a lot more in depth than everyone thinks.
Old Aug 20, 2011 | 08:15 AM
David @ Synchrotech's Avatar
Changing the gear ratio will not affect the emission results any more than a different tire size. The test is designed with an accptable RPM range at MPH and I doubt that a slight difference will change the results enough to matter.
FlinxSL
Jul 21, 2010 03:45 PM
cgo_62
Jul 3, 2006 04:27 PM
cgo_62
Jul 3, 2006 11:14 AM
red92civiccxhatch
Mar 10, 2005 02:56 AM
vile10
Oct 9, 2004 01:40 PM
