94 Civic A/C - Done All I Can Without Posting My Own Thread
Old Aug 18, 2011 | 06:29 PM
mrongey's Avatar
Default 94 Civic A/C - Done All I Can Without Posting My Own Thread
I bought a 94 civic 3-1/2 years ago with an A/C that doesn't work. Now that summer's almost over, i have decided to try and fix it. I've gotten closer based on the advice from other threads, but now I'm not sure what to do.
When I started, the condenser fan would kick on, but the pulley on the compressor would not spin, though I could turn it by hand with the engine off. The wire connector going into the low pressure switch was filled with grease. I cleaned it out, and low and behold, the compressor pulley began to spin off and on.
I filled the system with refrigerant up to the recommended pressure, and now the compressor spins steadily. The only problem is, I'm still not getting cold air.
What should I check now? Maybe the thermostat behind the glove box? I am on virtually no income right now, so I can't afford to take it into a shop, but I would at least like to know what is wrong with my system.
Thanks for any advice you can give!
Old Aug 18, 2011 | 06:42 PM
Former User's Avatar
Default Re: 94 Civic A/C - Done All I Can Without Posting My Own Thread
Was the system empty when you recharged it? Did you replace the receiver/dryer, place the system under deep vacuum, and leak test it prior to recharge? What weight of R134a did you add?
Old Aug 18, 2011 | 08:24 PM
bigJOE671's Avatar
Read this thread before you do anything to your car again and follow his instructions to the T. https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%5Bfaq%5D-how-charge-your-c-air-conditioner-conditioning-system-home-1665946/
Jeremy445
Honda Civic (2001 - 2005)
Jun 2, 2016 11:06 AM
Romach
14
Jul 21, 2013 05:15 PM
sirmugenpower
Jun 15, 2011 09:57 AM
diehlr
Jun 9, 2005 05:38 PM
