FL 99 Civic Si Clone Turbo Full kit Fully built
Old Aug 18, 2011 | 05:56 PM
jdmrisingsun's Avatar
Default 99 Civic Si Clone Turbo Full kit Fully built
This is a original 99 dx coupe transformed into a ligtweight beast Comes ready and built for boost a turbo. This engine has never had a turbo setup or nos never been to the track or beaten on. The car has a kelkey blue book value of 5785. Ive owned the car for five years and second owner never had a problem with it andI kno every part on this car. Read everything in this post before contacting me please. The car was stock when I bought it and now it has Only 77 thousand miles on car and about 10 on rebuilt engine has been garage kept all five years. This is an awsome setup and hate to let it go but my loss is your gain. This is my second vehicle so i am in no rush to sell it. No lowballing and rather negation in person. serious inquires only! No trades! The parts alone cost me 6 thousand so deferentially getting a steel. Call or text (561) 758-9737 again no lowballing. Best offer expected. The parts list below is to much to remember so some items are not listed. Intercooler gauges turbo and all oil lines included. including the tapped oil pan wich is already on there and the t fitting for the oil line.
Engine
New oil pump shimmed for better flow
New water pump
New Je piston n ring setup
New Eagle h beam rods
New npr or nrp crank and journal bearings
New Gator performance timing belt
New Swerve motorsports custom valves retainers and springs
Arp head studs
New cometic head gasket
New Dual core aftermarket aluminum radiator with electric fan new hoses
Z6 head on a Y7 non beaton on block.
Y8 tranny with low miles
New Excedy street disk with low pressure plate
Chipped on neptune needs basemap
obd2 to obd1 conversion harness
Y8 manifold
Z6 throttle body
Fully machined head and block honed regurduled crank was rebalnced
head has a minor port n polish was resurfaced and valves seats resurfaced
Brand new oil pan gasket
Oil pan tapped and ready for boost welded a plate to oil pan to have more grip for the bung in it right now
new ngk spark plugs and wires
new cap and rotor
Powdercoated z6 head
Powder coated valve cover color matched
Aem high flow fuel filter
255lp Fuel pump
Stage 2 axles
World sports 2 exhaust custom turbo piping made by apex industries
Energy support Mounts for the Engine mounts and Tranny mount
Headers minor leak.
New rotors slotted and slit
New brake pads
New rear drums
New brake cylinders
New shoes
Electronics
3.5 " single din jvc head unit with built in Bluetooth USB cord equalizer fully compatible with ipod hell of a head unit
12 inch Rockford p7 in an enclosed box
Powered by a 900 what audiobahn amp
Rockford fostgate 3.5
Probass 6.9 in the back with lifetime warranty
Viper alarm system
Exterior
Si oemfront bumper
Si oem hood
Si oem lip as seen in pics
Si grill
Fresh paint 2010 accord white custom color
Brand new Euro Chrome Headlights
Piaa Bulbs
Rota grid Rims
Brand New g force super sport tires
Suspension
Ground Control coilovers
Ground Control Resest Top hats about 2" lee way so you dont bottom out when slammed
Skunk 2 upper control arms all the way around with adjustable camber. good tire wear
Blox rear lower control arms
Agx adjustable Shock sturts 4 way adustable in the front 6 way in the back depending on how stiff you want your ride the shock struts themselvles also lower the car a bit.
Interior
The only thing i havnt finishedyet is the interior this is the work ive done to it. i am a great
painter as you can see by the car and when you come look at the interior.
I couldnt stand the grey interior so first i started prepping and painting the rear and the front
door things painted some small peices The entire rear of the car is done and everything but the dashboard
It is not ricer paint more like a stock honda black look to it like in the si version. interior seats all still grey
including the steering wheel. some things i have are Brand New gauges with New lines new vacuem lines and a
straight feed steel braided line to the gauge. also have black floor matts. and i am missing no parts to the interior.
i would give it a 7/10 to be honest because the grey on black doesnt look bad at all.
Old Aug 18, 2011 | 06:44 PM
bigpwr's Avatar
Default Re: 99 Civic Si Clone Turbo Full kit Fully built
so is the car turbo currently or just coming with turbo parts? sorry i couldn't find a direct answer in your description
Old Aug 19, 2011 | 03:04 AM
The car is currently does not have the turbo on it. Ive been building the engine before i put the turbo on. I also have 440cc nsx injectors to go with the kit. The turbo kit is brand new never used and includes everything needed. Lines Adaptors intercooler manifold everything you need to boost My loss is your gain.
mhx
Aug 16, 2005 11:24 AM
Turbo-Si
Oct 30, 2003 07:08 AM
