jdm DC sports header hittin my oil pan!
Old Oct 3, 2002 | 12:52 PM
CRexcellence's Avatar
New User
Default jdm DC sports header hittin my oil pan!
I just received my 4-1 jdm dc sports header, I have my motor up on an engine stand and when I put it on it was hitting the bottom of the oil pan...I have an ls/vtec and did the z10 block gurdle and had to get components from a gsr including the oil pan. Does anyone think that it is hitting because of the gsr oil pan? I bought the header for an ITR, but the motor is going into a crx...Ideas, opinions are needed...thanks
Old Oct 3, 2002 | 07:25 PM
Kg cm2's Avatar
Default Re: jdm DC sports header hittin my oil pan! (jrx2002)
bump
Old Oct 3, 2002 | 08:02 PM
Black DC2's Avatar
Default Re: jdm DC sports header hittin my oil pan! (Kg cm2)
same problem here
Old Oct 3, 2002 | 08:11 PM
lazerus's Avatar
Default Re: jdm DC sports header hittin my oil pan! (mighty goku)
Bend your oil pan out of the way.
Old Oct 3, 2002 | 08:17 PM
Lyonel's Avatar
I had a similar problem with a JDM ITR 4-1 on my B16a. Had to knock the pan back a little to get enough clearance. Just make sure you don't dent the area where the pick-up is.
Old Oct 6, 2004 | 10:37 PM
riceball777's Avatar
Default Re: jdm DC sports header hittin my oil pan! (CRexcellence)
to run a 4-1 header you need a gsr or itr oil pan
a b16/ls pan will hit the header
Old Oct 6, 2004 | 11:45 PM
91civicDXdude's Avatar
i ran a Megan Racing "type r copy" 4-1 header with 2.5" collector on my LS and it cleared the oil pan with no problems
Megan Racing
Old Oct 20, 2004 | 11:01 AM
trustbuddy's Avatar
Default Re: jdm DC sports header hittin my oil pan! (Lyonel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lyonel &raquo;</TD></TR><TR><TD CLASS="quote">I had a similar problem with a JDM ITR 4-1 on my B16a. Had to knock the pan back a little to get enough clearance. Just make sure you don't dent the area where the pick-up is.</TD></TR></TABLE>
how do you exactly "bend" a oil pan??????
sitinduk
Jan 11, 2008 06:39 AM
slow91crx
Welding / Fabrication
Jun 7, 2006 06:07 AM
ItrpwrdCrx
Sep 9, 2005 02:47 PM
92gsr1
Aug 15, 2005 05:01 PM
Naya the Dingo
Sep 24, 2002 03:32 AM
