My civic makes a weird noise when braking
Old Aug 18, 2011 | 07:55 AM
Pwnmeister's Avatar
Default My civic makes a weird noise when braking
My car is a 96 Civic hatchback and whenever I'm braking for a full stop, I would hear this weird noise. It sounds similar to a "stomping" noise and it's only coming from the back. I believe its the back on the driver side to be more precise. I usually hear it when my car speed is at around 20 mph coming to a full stop. At first i thought the noise was from the contact between my tires and the ground, but the tire pressure was good and lug nuts weren't loose.
I also tried moving/pushing the rear of my car left/right and down but heard no noise.
Could it be my struts? Because I know they're bad already.
Or tires not balanced?
It can't be rotors and stuff since the back are drum brakes.
Or what about the control arms?
Old Aug 18, 2011 | 08:28 AM
grumblemarc's Avatar
The Grumpiest
Default Re: My civic makes a weird noise when braking
Do you have ABS?
Old Aug 18, 2011 | 08:32 AM
Pwnmeister's Avatar
Originally Posted by grumblemarc
Do you have ABS?
Nope, no ABS
Old Aug 18, 2011 | 08:37 AM
The Grumpiest
Check bushings? RTAs?
Old Aug 18, 2011 | 08:38 AM
1991civiclx13's Avatar
removing the back wheels and checking your brakes would be a first, while there is no wheight on your rear end check strut mounts...
Old Aug 18, 2011 | 09:04 AM
Pwnmeister's Avatar
sorry not sure what you mean by RTAs
Could you be a little more specific about "checking your brakes"
thanks
Old Aug 18, 2011 | 09:11 AM
remove and inspect drums, check pads, check cylinder... (RTA) Rear Trailing Arm
SumOne
19
Jul 8, 2006 07:12 PM
DCnotTHEshoes
Oct 29, 2005 06:17 PM
ntrinsik
Aug 28, 2003 06:38 PM
shannon
Jul 31, 2003 06:36 PM
DeregginOut
Jul 4, 2002 11:40 AM
