Pulled quite a few codes need help with what to do
So I finally got my car working again and pulled the codes on it and it turns out I have 5, 6, 10, 14, and 36. I looked them up but I need to know how I should go about fixing these. I know where the problem is at just not how to fix it. Any help would be great.
You have a MAP sensor code, Coolant temperature code, Air Intake Temp code, Idle Air Control Code and I don't know what 36 is. I would check the plugs on the intake manifold to see if the sensors are actually plugged in. The coolant temp sensor should be on the left side of the block/head somewhere under the distributor.
