Suspension & Brakes Theory, alignment, spring rates....
how do i adjust steering wheel?
Old Aug 17, 2011 | 05:58 PM
TOO MUCH TORQUE's Avatar
Default asdfasd
adsjfasf
Old Aug 17, 2011 | 06:01 PM
kaiba's Avatar
Default Re: how do i adjust steering wheel?
Toe adjustment. Get an alignment it will make things easier. Should cost no more then $40.
Old Aug 17, 2011 | 06:32 PM
asdfasd
Old Aug 21, 2011 | 09:29 AM
boostedteg69's Avatar
there is a plastic cover under the dash that covers the steering linkage and all you have to do is remove that and there is a nuckle where the wheel part meets the pinion and its two 12mm bolts. make sure the wheels are straight forward and then unscrew those 2 bolts and just turn the wheel till its straight and put the nuckle back on and put it all back together
SuicideSlide
19
Sep 30, 2004 03:50 PM
neEven
Mar 23, 2004 11:55 AM
killa_lude
Jan 26, 2004 07:04 PM
kikkoboyie
Sep 15, 2002 02:55 AM
