fuel pump not turning on when it should..
Old Aug 17, 2011 | 12:57 PM
EGcivic_95's Avatar
Default fuel pump not turning on when it should..
okay i have a 94 civic with a ls (b18b1) in it and it has 450 cc injectors and a walboro fuel pump, well the past few months or so when i go in my car and turn the key over usually you hear the pump kick on then off well this is the problem ill turn the key on and all my instrament panel lights come on but the fuel pump will not and obveiously my car wont start...i have to repeatidly turn on and off the key for it to finally kick on but usually only takes a few times but today it took a long time atleast 20 minutes of doing this VERY frustrating..lol im not very sure what this is maybe a relay? idk but help will be appreiciated
Old Aug 17, 2011 | 01:05 PM
grumblemarc's Avatar
The Grumpiest
Default Re: fuel pump not turning on when it should..
WHY are you running a Walbro and 450s? Maybe give up ALL the info on your ride? Have you checked the main relay? Maybe even the ignition switch?
Old Aug 17, 2011 | 01:14 PM
EGcivic_95's Avatar
well im running them because it was boosted a few weeks ago im still gathering money for the turbo. and i hope the switch is not bad, would be quite hard to change seemigly the way its on the steering shaft lol but ill check the relay. how would i know the relay being bad? wouldnt it make the pump not work at all not just every blue moon?
Old Aug 17, 2011 | 01:42 PM
EsotericImage's Avatar
Retired Moderator
check the relay
check wiring with multimeter
then come back and tell us what its reading
Nonvtak monster
Aug 28, 2013 09:53 PM
Nicholas Harvey
Jul 16, 2013 01:55 AM
EfSedanLove
Dec 29, 2008 07:38 PM
crazyimport
Sep 2, 2008 09:22 AM
2camsaam
Jul 14, 2003 09:09 AM
