95 civic ex with 97 gsr swap stumbles on acceleration?
Old Aug 17, 2011 | 12:22 PM
dinthanonh's Avatar
Default 95 civic ex with 97 gsr swap stumbles on acceleration?
i have a 95 civic ex with a 97 gsr swap and it stumbles on acceleration. it only stumbles if i press on the gas to fast. it does not do it when i accelerate slowly. it also bogs down or cuts off when i press the gas pedal too fast. sounds like its not getting any air. and it doesnt rev past 7000rpm. its also hard to start, but it idles fine. it idles right at 800rpm. i tried changing ecu's. tried a stock p28 and a stock p72. no cel's. also checked all the wiring. all of it is plugged up right and all the wiring is good. could anybody give me some advice?
Old Aug 20, 2011 | 05:19 PM
dinthanonh's Avatar
Default Re: 95 civic ex with 97 gsr swap stumbles on acceleration?
nobody?
Old Aug 20, 2011 | 08:29 PM
Former User's Avatar
When was the last tune up and what was done? Is the ignition timing set to spec?
Old Aug 21, 2011 | 06:07 PM
dinthanonh's Avatar
i just put the swap in. basically everything is new, from timing belt to ignition coil. made sure timing was set to spec. one thing i didnt change was the fuel pump. it has the stock ex fuel pump. do you think its my ecu's. maybe both are fried? or maybe i need to clean the fuel system?
Old Aug 21, 2011 | 06:11 PM
Hidenplanvew's Avatar
check spark, fuel and timming... Might have a coil going out
Old Aug 31, 2011 | 12:27 PM
dinthanonh's Avatar
thanks everyone..the problem was the dizzy. even with a new coil pack it was bad. maybe the ignitor
Wolfmonkey
Mar 19, 2018 10:02 PM
russ.shafer
Jan 12, 2012 12:05 AM
Billy1997
Jul 17, 2011 01:26 PM
tdizz07
Mar 17, 2006 09:20 PM
azn_outlaw
Nov 5, 2001 02:09 PM
