Urgent Technical help please . Honda B18b and Honda B18c Block
Old Aug 17, 2011 | 11:15 AM
djspeid's Avatar
Icon2 Urgent Technical help please . Honda B18b and Honda B18c Block
i need technical help..
can a b18b non vtech crankshaft work and perform well in a b18c typeR vtech block?
note its purpose is for track racing...
your answers will be truly appreciated...
djspeid's Avatar
Default Re: Urgent Technical help please . Honda B18b and Honda B18c Block
can email me at speid_speidy@yahoo.com
Old Aug 18, 2011 | 02:37 AM
boostedteg909's Avatar
if u use an ls crank u must use ls length rods. but u prolly already kno that. if ur lookin for a lil more torque than strokin it would b a way to go. ive heard it called the poormans stroker. they work very well together
Old Aug 18, 2011 | 10:29 AM
turbodcxbro's Avatar
Yes, it works and works well. B18C crank is 87mm stroke. The B18B crank is 89mm stroke so you are +2mm. As said above you do have to use the LS/B18B rods though and you will also likely have to remove the oil squirters on your B18C because they won't clear...
mrlover
Apr 9, 2006 08:29 PM
methanemotorworks
Feb 14, 2006 08:32 AM
slowhatch95
May 26, 2002 02:15 AM
Project SSAP1
Jan 29, 2002 10:39 PM
Project SSAP1
Jan 29, 2002 09:03 AM
