Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Installed new oxygen sensor now reads Code 134?
Old Aug 17, 2011 | 06:20 AM
Pothole987's Avatar
Default Installed new oxygen sensor now reads Code 134?
So i just installed my new oxygen sensor, replaced the original because of code 135 which is heater circuit malfunction, and now i have code 134, which means oxygen sensor inactive
Does this mean the oxygen sensor is bad??
Old Aug 17, 2011 | 11:56 AM
It Wasn't Me's Avatar
Default Re: Installed new oxygen sensor now reads Code 134?
Bad sensor, or it was installed incorrectly.
Have you tried resetting the ECU?
Old Aug 19, 2011 | 08:14 AM
Pothole987's Avatar
i erased the codes with a scanner. code would go away for a minute, then come right back, should i reset the ecu?
and it was a direct install, it was made for the car so i would hope it was installed correctly
Old Aug 21, 2011 | 01:33 PM
lazlong's Avatar
Did you get the right sensor? Does the new one look exactly like the old one?
Old Aug 22, 2011 | 09:06 AM
Pothole987's Avatar
almost the same, had one black rubber piece in the middle, but the seller off ebay just told me that the sensor is made for a GX,
http://en.wikipedia.org/wiki/Honda_Civic_GX
LOL so yeah im back to square one.
Old Aug 23, 2011 | 08:22 PM
Pothole987's Avatar
Has anybody heard Of a Civic GX? apparently it runs of Compressed natural Gas.
Im just wondering what the difference would be in oxygen sensor since the plugs are the same and how they are wired are the same.
maat4449
Honda CR-V & Element
Jan 10, 2011 10:58 AM
dbailey
21
Nov 9, 2007 07:08 AM
ham
Apr 13, 2007 07:43 AM
