96 missfireing
i have some problems....my cel port will not connect to any scanner that is pluged into it and im having some sever miss fire......full tune up and new dizzy so please help and yes its the f22b2
When did the problem started?Just out of nowhere?Was the tune up done for a reason or just trying randomly to fix it? Confess man !
.You know more than we do.
how it all started....driving down the interstate (60 in 4th) and cel came on and went to limp mode put a scanner on it and it was the pickup in the dizzy so bought a used dizzy and it ran fine for 2 days then all over again so i bought a brand new dizzy cap rotor plugs and wires and still missfiring now im at a stand still....
Well, start with simple stuff. Pull the spark plugs, take a look at them make sure they look normal and are gapped correctly.
I had a bad misfire problem, turned out I had the typical distributor leak. It's easy to check, pull out the 3 screws that hold the cap up, and if you see jizz in there you got a problem.
Do you have a compression ?
Does all the injectors have pulse?
Does the injectors work?
(you can put a screwdriver to each injector and listen to the clicking noise)
Check the conditions of where the spark plug wires meets the coils. Maybe there's a crack in them. Also check if your spark plug tubes is nice and dry. Even a slight hint of oil may be bad.
just put the "valve cover gasket kit" in along with a full tune up! car runs but has a bad missfire and in limp mode.....i have tryed to hook a code reader to it and the reader said not conected talked to honda and they said the ecu might be bad from the fact the code reader will not connect to the vehicle....
I think you're getting too hung up on getting the code reader to work. You pulled the codes using the blue connector and a paperclip and got a code 41, right? I believe that's an open primary oxygen sensor heater. Check the codes again and confirm.
my '94 developed a horrible miss under light acceleration or when trying to maintain speed. Felt like driving over railroad tracks. Cleaning the EGR ports = fixed.
