WEIRD brake problems
Ok so I had my car up on stands for like.. close to 4 months.. I just finally got my suspension on and now i'm having a weird intermittent brake problem..
I start the car up, put foot on brake, pedal feel is fine.. i backe dit down my driveway and pedal went to the floor with hardly ANY braking power. I let up to turn the car to the left and then pressed the brake really hard expecting it to floor again, and pedal feel was normal. This happened 3-4 times in the past couple of days while I have been moving my car in/out of the garage.
Any ideas? Could my coilovers be pinching the front brake lines causing this? Its not leaking a drop so nothing is torn or broken..
I will bleed them tonite and throw new brake fluid in to see if that helps. Air bubble maybe?
Any ideas?
Lates~
Any ideas?
Lates~
Make sure your axle nut is tight. I had that problem and the rotor would kind of flop around and push the pistion back. IT would feel soft till the pistion settled the rotor back.
It's probably your Master Cylinder like the first guy said. Are the brakelines pinched? If they are, that's your problem. Otherwise, try taking apart the whole brake assembly, and put it back together. See what happens, but I'm guessing somehow, there's lots of air in your brakelines....and that's not good.
da1lydr1ver
Mar 26, 2012 06:25 PM
