milky oil
So I just finished putting together a b16 and i started leaking oil from my cam seals. As I was replacing them, I noticed that my oil was milky. I drained my oil from the motor, replaced the headgasket, and put coolant in the radiator. put in about 3/4 of the coolant mix and I am noticing that coolant is coming straight out of my oil pan. When I took off the head, coolant passages in the block were still holding coolant. What could my problem be?
Thanks
Thanks
would you happen to be running a oil cooler like the factory one on a b18c1? It has been a long time since i have looked at a B16 and cant remember if they run it or not. It looks like a spacer infront of the oil filter, with 2 hoses coming from it
GSR's do not come with oil coolers from the factory.
I have seen people hook yp the coolant lines coming off the coolant pipe in the back of teh motor incorrectly. Runnin them from the coolant pipe into the manifold instead of to the IAC valve.
Just a thought
Just a thought
92jdmhatch
10
Dec 28, 2004 07:53 PM
