96 civic a/c compressor wiring questions.
Old Aug 15, 2011 | 04:34 PM
96electronH's Avatar
Default 96 civic a/c compressor wiring questions.
i know that the ecu energizes the compressor relay by providing a ground source. but what does it provide the ground based on?
Old Aug 15, 2011 | 08:45 PM
Former User's Avatar
Default Re: 96 civic a/c compressor wiring questions.
If you look at the circuit diagram, you'll notice that two different A/C wires pin to the ECU at A17 and C5. This allows the ECU to be notified whenever the A/C is turned on so that the ECU can delay activation of the compressor clutch for a couple of seconds until the idle speed is raised high enough to compensate for the increased load. It works like this:
1) Reference voltage (5V) is produced by the ECU at pin C5 whenever the key is on.
2) Pushing the A/C button to turn the A/C on grounds the reference voltage at C5, signaling the ECU to raise the idle speed.
3) After the idle speed is ramped up, the ECU then supplies ground to ECU pin A15 to activate the compressor clutch relay, which causes the compressor clutch to engage.
Old Aug 16, 2011 | 02:49 AM
Ok i understand now thanks for clearing that up.
vader007
Nov 8, 2022 07:25 PM
likeaSIR
Honda Civic (2001 - 2005)
Jul 14, 2013 07:18 PM
Hooptiehonda
53
Sep 18, 2011 10:28 AM
chulew
Aug 30, 2009 08:38 AM
na.civic
Engine Management and Tuning
Aug 19, 2009 08:12 PM
