B18C to B18B. Need some opinions.
Old Oct 3, 2002 | 10:36 AM
StockTeg's Avatar
Default B18C to B18B. Need some opinions.
I know it sounds stupid but I can get a B18B that is built up and has great all motor power for a good price. Now the question is should I get rid of my B18C(which is stock) and buy the B18B(with lots of mods)? No negative comments please. Just need opinions that can help with my decision. Thanks.
[Modified by StockTeg, 7:36 PM 10/3/2002]
Old Oct 3, 2002 | 10:39 AM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
Default Re: B18C to B18B. Need some opinions. (StockTeg)
dont you dare! The b18c has soo much more potential. You would have to be stupid to do this! If you can get the b18b for a good price then get it and drop it into a hatch.. then you will have 2 bad *** cars!
Old Oct 3, 2002 | 10:45 AM
allmotorls95's Avatar
Default Re: B18C to B18B. Need some opinions. (Hatchy-Ownzjo0)
um a b18b just has as much power potential as a b18c....its all up to u..
Old Oct 3, 2002 | 10:47 AM
Audi A4's Avatar
Default Re: B18C to B18B. Need some opinions. (allmotorls95)
damnnnn.... how many times is it gonna be covered????? do a search....
theres 50 billion comparisons on here.
Old Oct 3, 2002 | 10:49 AM
Leimokei's Avatar
New User
B18C that's a freaking jdm type R...why the hell would u want to downgrade...(just kidding) both motors have potential either way you look at it, just depends on which route you plan on going and how much money u want to spend..if i were you i stick with the b18c1 and build it up...you won't be dissapointed...
Old Oct 3, 2002 | 11:23 AM
The Rob's Avatar
Default Re: B18C to B18B. Need some opinions. (Leimokei)
Old Oct 3, 2002 | 12:02 PM
maggsgsr's Avatar
Default Re: B18C to B18B. Need some opinions. ( Zero)
Stay with the b18c1
Old Oct 3, 2002 | 12:09 PM
smdandb2's Avatar
Ill give you $50 for your b18c1... lol
Old Oct 3, 2002 | 12:45 PM
sutrusu's Avatar
hahahah are you joking?!!!?!?!? all motor b18b is a complete waste of money.
Old Oct 3, 2002 | 12:50 PM
4DoorLS's Avatar
Default Re: B18C to B18B. Need some opinions. (sutrusu)
Can u elaborate what the B18B includes? Is it an LS-Vtec setup?
Old Oct 3, 2002 | 12:57 PM
brinks's Avatar
I agree totally. The B18b (LS) block may have some redeeming qualities, but we can all agree, the head is nowhere near as good for making STREETABLE powe as a vtec head.
Old Oct 3, 2002 | 01:00 PM
maggsgsr's Avatar
Default Re: B18C to B18B. Need some opinions. (brinks)
Yea after about putting a GSR,TYPER,orSI head on it,it has the same potential.
Old Oct 3, 2002 | 02:01 PM
lshobo's Avatar
Default Re: B18C to B18B. Need some opinions. (maggsgsr)
sig says he has a 94gsr. depending on the condition and mileage of the b18c, it might make sense to buy an ls motor for cheap, and build it. of course, he'll lose the godly VTEC.. oooahhhooh. but then there's vtec head, boost, or both. or just stick with the b18c and put your money into building it up and making sure it runs smooth. it is definitely a better platform to start with in terms of allmotor imo
Old Oct 3, 2002 | 06:44 PM
H-T Poker champion
Default Re: B18C to B18B. Need some opinions. (lshobo)
So... Put a VTEC head on it to give it as much potential as the b18c... wow.. that must mean.. OH NO!! The B18C DOES HAVE MORE POTENTIAL!!!?? HOLY **** I WAS RIGHT!
Old Oct 4, 2002 | 06:41 AM
StockTeg's Avatar
Default Re: B18C to B18B. Need some opinions. (4DoorLS)
The b18b has the following,
1994 LS Block
1999 LS Head
Crower 403 (Stage 2) Cams
AEM Cam Gears (Red)
Crower Ti-Retainers
Crower Daul Valvesprings
Port & Polish (Done by Race Designs down in Cali)
3 Angle Valve Job (Done by Race Designs down in Cali)
Port-Match Intake Manifold
Distributor
Thottle Body
HCP Motormounts
HCP Shift Linkage
LS Haft Shaft
Raxle Axles
B&M Fuel Pressure Regulator
B&M Fuel Pressure Gauge
New Starter
Alternator
Injectors
LS Tranny (Needs new syncros)
LS Rear Tranny Bracket
LS Engine Mount Bracket
LS Hubs
PR4 ECU
B16 Clutch
Clutchmaster PP
GSR Flywheel
It makes 176 whp and 152 lbs of torque.
Still has room to improve.
[Modified by StockTeg, 3:49 PM 10/4/2002]
Old Oct 4, 2002 | 06:48 AM
StockTeg's Avatar
I think I'm just going to sell my GSR and buy a hatch and put that baby(b18b) in. 13s would be no problem. I've always wanted a hatch.
Old Oct 4, 2002 | 06:54 AM
Project X's Avatar
1994 LS Block
1999 LS Head
AEM Cam Gears (Red)
Crower Ti-Retainers
Distributor
Thottle Body
HCP Motormounts
HCP Shift Linkage
LS Haft Shaft
Raxle Axles
New Starter
Alternator
Injectors
LS Hubs
PR4 ECU
B16 Clutch
Clutchmaster PP
GSR Flywheel
That's a BS. A 1.8L can't make that much torque at wheel. Even with 12:1+ CR pistons, you won't be close to that tq number.
Another thing is that 403's w/ P&P head won't get you a 176 whp.
You should ask for a dyno graph for that car to make sure.
Old Oct 4, 2002 | 07:40 AM
Steve-o's Avatar
i am not going to give you any negative feedback but i would stick with the gs-r but that is just me but i know you can get alot more out of a B18C..it might take more money on yuor part but in the end it will be better if you stick with the gs-r. it already has the Vtec system!!! wich you know is one of the great things that Honda has done in tuning there cars!
Old Oct 4, 2002 | 07:47 AM
AudioXtremes's Avatar
so then how much you want for your gsr???
Old Oct 4, 2002 | 08:23 AM
BoostingLS's Avatar
1994 LS Block
1999 LS Head
AEM Cam Gears (Red)
Crower Ti-Retainers
Distributor
Thottle Body
HCP Motormounts
HCP Shift Linkage
LS Haft Shaft
Raxle Axles
New Starter
Alternator
Injectors
LS Hubs
PR4 ECU
B16 Clutch
Clutchmaster PP
GSR Flywheel
NO way that has 176whp wit that tq. w/just cams n a head job, nope not with an LS buddy. keep your gsr, don't be dumb
Old Oct 4, 2002 | 10:40 AM
H-T Poker champion
Default Re: B18C to B18B. Need some opinions. (BoostingLS)
Lets see that dyno plot... Cuz if not then i call bull ****. Oh, and a 1.8 liter can have a hella lot more torque then that.. its called turbo man...
Old Oct 4, 2002 | 11:09 AM
LOwrestling2001's Avatar
no way it makes 152 ft lbs tq...my SCed car makes 230 whp and 162 tq...dyno in sig...but yea no way an all motor LS will make that much...hell...no way an all motor with a b18 block of any sort with only cams will make that much tq.
Old Oct 4, 2002 | 11:42 AM
piatl7il77's Avatar
how much for the b18c
Old Oct 4, 2002 | 12:52 PM
Default Re: B18C to B18B. Need some opinions. (piatl7il77)
damn u guys need to get off ur vteck trips.....
Old Oct 4, 2002 | 01:18 PM
StyleTEG's Avatar
Default Re: B18C to B18B. Need some opinions. (LOwrestling2001)
heh, really?
http://images.team-integra.net/~team...dynos/lip1.jpg
Clutchmasters stage5 clutch package with extreme Pressure plate
» head milled roughly 3-5thou to clean(literally) the surface
» Oil line routed from block to head(remember the block off)
» B18C5 block resleeved (thicker)and bored to piston specs
» GSR head worked extensively including filing and porting
» Head and Block Sealed Off for VTEC Oil Passage
» MSD rpm activation switch for vtec activation
» Endyn 84.5mm 13.1:1 compression pistons
» matching to twm ITB's and cloverleafed
» TWM 50mm Individual Throttle bodies
» Endyn/Moroso crank breather system
» 9200rpm ignition and fuel cutoff
» Jacob's Electronics Ultra coil
» Eagle rods (gsr stock length)
» 0.5mm oversized ferrea valves
» Unorthodox underdrive pulley
» Portflow titanium retainers
» Toda second gen cam gears
» HyTech prototype header
» Honda crv head gasket
» TWM 440cfm injectors
» DFI fuel management
» MSD distributor cap
» TWM fuel regulator
» Toda valve springs
» Toda Oil pump gear
» Toda Spec C cams
» MSD 8.5mm wires
» Toda flywheel » ITR Crank
» MSD 6al
B18C5
» Max Power (HP): 241.7
» Max Torque (Ft-Lbs): 157.2
