Code 7 TPS CEL - HELP!!
Old Aug 14, 2011 | 01:02 PM
boostjunkieee's Avatar
Default Code 7 TPS CEL - HELP!!
I have a 95 Civic coupe with a JDM H22a swap and im getting a Code 7 CEL - Throttle Position Sensor. I checked the voltage at the sensor and its reading .004v with the throttle closed and 3.3v at wide open throttle. I've researched and found it should be .4-.5 closed and 4.5-5 at WOT. I adjsuted the TPS but the voltage only drops lower. The car idle's and runs fine, but it keeps throwing the CEL, does the TPS need replaced because of the lower voltage? Is it starting to go bad?
boostjunkieee
13
Aug 18, 2011 08:46 PM
Rayog21
Aug 26, 2009 08:31 AM
EkLanta
Nov 5, 2007 04:38 AM
dsadas89das78934
11
Aug 27, 2004 06:47 AM
SuzukaBlueAP2
Oct 16, 2003 02:39 PM
