What mounts do I have? eg/h22
Ok so long story short, I bought some mounts from a member on here and they bolted up fine. The member told me they were hasport and they also had hasport stickers on them. I have been researching and am not so sure they are anymore. They are grey in color and have red inserts. The mounts look ok aside from the passanger mount. It looks like the hasport mounts hat I have seen come with a bracket that bolts to the frame. Mine actually bolts up to the bottom of the frame using 2 heavy duty bolts. Do I have hasport mounts? Any help is appreciated. Thanks
ok this is the only pic I could get ahold of right now. I actually had to mod the driver side using a different mount (whole other story) but I did have this one on me. Dont know if it will help.
[IMG=http://img546.imageshack.us/img546/6237/hasport1.jpg][/IMG]
I know it says hasport on it but like I said above where the transmission bolts to the frame on the passanger side it bolts from the bottom using two bolts. It actually had a plate that bolted to the transmisson. The plate had a shaft looking thing on it. The shaft slid into a hole of a triangle looking bracket. The triangle bracket had the two holes that bolted to the frame. I dont know if that explanation was worth a sh*&^ but I gave it a shot.
