98 ex/b16A swap - What A/C compressor bracket is needed to reinstall A/C system?
Old Aug 13, 2011 | 06:10 PM
4doorteggy's Avatar
Default 98 ex/b16A swap - What A/C compressor bracket is needed to reinstall A/C system?
Ok well im in the process of putting a/c back in my 98 ex coupe. The car has a b16A swap. I have everything i need to put it in except for the compressor bracket and belt.Now my question is which bracket am i supposed to use for the a/c compressor?I will be using a compressor off an 2000 integra, I am asking for some info because i have read so much on the web already and everything i look at is all different and just confuses me I know i can use the 98 crv bracket or the delsol bracket that came with a b16, But are those my only options for the compressor im using or should i use a different compressor all together?...any info is appreciated
Old Aug 14, 2011 | 06:57 AM
4doorteggy's Avatar
Default Re: Cant take the heat!...A/c questions inside
54 veiws and nothing thanks ht...
Old Aug 14, 2011 | 07:29 AM
delsolo95's Avatar
its been done numerous times but ill help since im here. not to sure about the integra compressor but on my civic with gsr swap i used the b20 ac bracket mount or you can get the dohc vtec del sol which is a little more pricy brand new. with that specific bracket i used the stock civic compressor, which will bolt up perfect, and use any b series ac belt( part # are different but some are shorter n some longer, but thats easy fix with the tensioner. also get any b series a/c tensioner, all the same. connect ports, flush, and fill.
Old Aug 14, 2011 | 07:50 AM
Former User's Avatar
In the future, a more informative thread title would probably help to get you quicker answers to your questions. Title edited.
Old Aug 14, 2011 | 08:33 AM
4doorteggy's Avatar
Which crv bracket is the one i need because i was told that the 5 spd one and automatic one differ
Old Aug 15, 2011 | 04:18 PM
96electronH's Avatar
Default Re: 98 ex/b16A swap - What A/C compressor bracket is needed to reinstall A/C system?
bump for answer
dijitalbuddhist
15
Mar 3, 2014 09:33 PM
Zaakro
Nov 12, 2005 04:34 PM
ghettochild
Nov 27, 2002 11:46 AM
