mini me timinng question
i have a d15b2 block with a d16z6 head ive done a lot or research and i know the timing is going to a half tooth off but is it going to be a half tooth retarded or advanced
1 tooth is 9* off centerline so 1/2 a tooth is 4.5*... using tha setup you will be 4.5* advanced. Set your ignition timing to 16* BTDC regardless... be sure to jump the service connector first... Best bet is to get an adjustable cam gear if you want to dial in the mechanical timing...
x2
i lost my job other wise i would have an adjustable cam gear im trying to make do with what i have but thanks for the info ill be working on it agen Wednesday and try what you said
Big Skeet3817
Engine Management and Tuning
Sep 2, 2009 02:40 PM
O16581724 5 2 5
Jul 5, 2006 07:29 AM
