No compression after ARP head stud / headgasket install
Old Aug 13, 2011 | 03:47 PM
XpL0d3r's Avatar
Default No compression after ARP head stud / headgasket install
Just installed new ARP head studs & a new MLS head gasket on my boosted LS... All went well, went to fire her up... 0 compression, just spins freely.
ARP studs are down to 62 ft-lbs, though I've heard to go to 65, 76, and 80.. Not sure which one to go Do but it felt like they were going to snap at 62..
Any ideas? Boosted LS in a 1997 EJ6 sedan..
Old Aug 13, 2011 | 04:13 PM
mouab18c1's Avatar
Default Re: No compression after ARP head stud / headgasket install
Timing?
Old Aug 13, 2011 | 04:46 PM
XpL0d3r's Avatar
Originally Posted by mouab18c1
Timing?
We marked the timing belt and cam gears before doing anything, but I'll check to see if it's lined up with the crank.. Hmm
Also, is 62 ft-lbs for arp studs too low? I haven't really found a solid answer on what to torque them down to...
Old Aug 13, 2011 | 05:24 PM
TypeRMOBBiN209's Avatar
no sparkplugs?
Old Aug 13, 2011 | 05:31 PM
hybridmiklo's Avatar
No compression? That's an automatic timing off.
Old Aug 13, 2011 | 07:47 PM
mouab18c1's Avatar
Exactly, that's what I'm saying. Make sure everything is lined up at TDC.
Old Aug 13, 2011 | 07:54 PM
209lsr_ly's Avatar
0 compression as in u did a compression check or as in it won't start?
Not trying to by an ***.
Old Aug 13, 2011 | 10:07 PM
XpL0d3r's Avatar
Timing was off 90*, somehow. Fixed, runs great minus something fell into the lower timing / crank area and makes a clanking noise at random times. Going to fish it out tomorrow
Old Aug 14, 2011 | 12:35 PM
NyCloneEkSi845's Avatar
good job on finding the issue
protopro88
Jan 17, 2012 10:10 AM
TravisCadello
76
Apr 10, 2009 11:03 PM
DUHC
Oct 14, 2008 06:41 AM
dskater4111
Aug 13, 2008 05:17 AM
McFly
Mar 29, 2003 12:38 PM
