96 civic FAN problem
Old Aug 13, 2011 | 01:09 PM
jhines1211's Avatar
Default 96 civic FAN problem
I have a 96 civic and ive had my car in the shop 2 times for overheating problems due to fan not coming on. Both shops ive gone to have just replaced the fuse and the actual switch to the fan, it will come on for 2 days and then just stop coming on. I believe it's an electrical issue but what would cause that? and what do i need to replace to fix that? Has anyone else had this issue..thanks
Old Aug 13, 2011 | 02:21 PM
Former User's Avatar
Default Re: 96 civic FAN problem
Are you losing coolant?
Start here:
Bleeding the cooling system may take 20-30 minutes.
1) Park the car on an inclined driveway with the front end higher than the rear.
2) Push/turn the dash heater lever/**** to MAX heat. Fan need not be on.
3) Follow the directions in the diagram below
Old Aug 13, 2011 | 02:39 PM
jhines1211's Avatar
its only overheating when im slowing down or stopped, when im driving my car stays somewhat cool. When i stop the car and let it run it starts to come out of the res, and my hoses have no pressure...ive had my block tested for headgasket so i know that isnt the problem.
Old Aug 13, 2011 | 02:53 PM
Your response does not negate my suggestion or question.
EK9JSPEC
Sep 19, 2012 07:39 PM
crazycivichatch
Aug 6, 2006 02:38 PM
mstewar
Jan 24, 2006 03:57 AM
v.i.gsr
Dec 12, 2004 05:17 PM
