track times today
so i took my car to the track today my best time was a 14.8 @ 95mph with a 2.3 60 ft had issues spinning and wheel hop def needs a dyno tune too im not to happy with my mph though hoping to bring that up with dyno tuning and maybe switching to a big tube header
b20vtec
je 10.5:1 compression pistons
aebs intake mani
edlebrock 65mm tb
hytech rep small tube header
3 inch exhaust
3 inch short ram intake with vstake
eagle rods
gsr head milled about .012
skunk2 tuner stage 2 cams
its only been street tuned it needs a lot more tuning i wanna change the header and get it to a dyno to get tuned
aebs intake mani
edlebrock 65mm tb
3 inch exhaust
eagle rods
Definately get it dyno tuned. This is the best way to find MBT at every rpm point. Getting tuned can be a night and day difference.
As for tranny concerns and falling outta vtec, get tuned and see if you can shift a little higher..
Invest in a set of slicks. Wheel hop kills axles and stress transmissions. Slicks will also drop your times waaay down. One of the best bang for your bucks if you ask me. $300 might get you another half a second.
I'd also try a longer intake and makes sure you have cold fresh air coming in. Hot intake charges kill HP...
Whats the weight of the car and driver total?
lol weight of car and driver is a killer its a full interior 95 gsr so id say about 2600 plus im no small dude im about 250 lbs i know the car would do much better times in a lighter chassis and with a lighter and better driver but its my trap speed im more concerned about. id like to hit the 200 whp mark and if possible hit 13 sec times. my goals for the car arent outrageous just a 13 sec daily driver and im happy
Skunks Tuner2 like vtec around 5-5500. If your shift out at 8600 in a gsr tranny you should be landing around 6700 or 6500 rpm's.....how are you falling out of high camcam
negusjuda
Don't change your tires yet. Please get some more seat time. If you are not getting good times on street tires switching to slicks or drag radials will just yield bad times with those. In my case on Summer performance tires with the OEM suspension I was able to cut 2.0-2.1's, I have yet to try on my Falkens with the Koni Eibach suspension, maybe 1.9-2.0.
I also averaged over 100 runs a year. Seat time is your friend.
As for gearing. Wait. Get it tuned, VTEC maybe set incorrectly or even your fuel cut.
might not be a gsr trans we was thinking it may be a ls trans because im barely hitting 4th gear threw the traps my vtec is set to 5600 going from 1st to second it drops out of vtec
This is right, my GSR only drops about 2000rpm when I shift. I also don't let off the gas but that will come with experience.
negusjuda
negusjuda
stamp means nothing because i have seen ls and gsr with same stamp the car is a 95 gsr i did the 80 mph test in 5th gear im at 4000 rpm but that can be wrong if my tach is off which it is by 10 mph or so at 4000 rpm im at 83 mph
If you're barely crossing the line @ shifting into fourth, it sounds as if you have a ls tranny..
y80 can be two different trannies
a b18b1 or a b18c..
Majority of the time what i do for people is street tune their car.. Reading plugs, and getting the AFR pretty close to steady. Then a dyno trip would be in order to fine tweak things.. this saves yourself time and money, instead of spending 1-2 hours on a dyno, you spend maybe 30-45mins.. Then another street tune or track tune.
Street tuning puts "real" world load on the car, where aerodynamics actually come into play.. putting the car on the dyno with straps doesn't do that unless you have a good dyno where you can change load settings.. some shops do not have this. And thats why track tuning will yield better 60's and short track setups.
yea i know but the guy i had tuning it dosent take the time to do any of that he just tunes air fuel and make sure timing is what it should be in stock form and yes we kinda figured once we tracked it that its probably a ls tranny which i was actually planning on getting a b16 or itr tranny if i could only good thing about the tranny is it has a lsd
did u go to cali speedway i was driving the white eg on black/red stripe ls mesh street tire i got a 14.9 my best time stock ls block stock gsr head and manifold type r header, my 2step was hella too low and i would dead hook off the line and go nowhere my 60' was 2.3 my car was the car that backfired when i shift
i also ran my friends b20 ef it had a carbon hood with stickers all over it and i got 14.3 out of that all motor b20 non vtec on street tires bogging out of the hole
my friends h22 eg ran 13.6 all stock on street tires
time to step up from b to h
thats what im gonna do
