What management should I get for my 99 SI Turbo project?
Old Aug 13, 2011 | 11:49 AM
99siky's Avatar
Icon2 What management should I get for my 99 SI Turbo project?
I have a 99 SI. Pretty much factory. Has an intake, greddy header, and different muffler (done before I got it). I have a turbo I want to install at 6-8 PSI. Don't want to change internals or anything else. Just want to run low boost with factory set up. What computer management system should I get that would be the easiest and quickest. Hondata seems to be the norm with everyone I talk to but I don't really want to switch to an OBDI. Is there a way I can keep my OBDII. Like I said before I am not looking to run massive amount of boost or mods. Just something to make it get around 180-200WHP. I know about engines but not the import game. I mainly rebuild mustang engines(big difference from a honda). Any help would be greatly appreciated.
P.S. can I run the factory fuel pump on this setup as well. I know I have to get bigger injectors but I am not sure if the fuel pump is up to the job or not.
Old Aug 13, 2011 | 12:08 PM
Former User's Avatar
Default Re: What management should I get for my 99 SI Turbo project?
Thread copied to both the Forced Induction and Engine Management forums.
Old Aug 13, 2011 | 12:19 PM
grumblemarc's Avatar
The Grumpiest
If you have to ask these questions then you are no where NEAR ready to even start thinking about boosting your car.
#1 - You don't have to switch to OBDII. You only have to run an OBDI ECU via a conversion harness and the ECU has to be socketted and chipped. THEN You can run whatever EMS you want-<CROME>, Hondata, Neptune... It's not the same thing.
#2 - If you still don't want to convert anything over then be prepared to fork out about a grand to run the AEM unit with your stock ECU.
#3 - You probably should ask your TUNER what they are proficient on then follow their advice and buy whatever it is they tell you to.
#4 - What turbo?
#5 - A stock B-series engine is good for about 300 horsepower.
#6 - There is nothing EASY about boosting a car. Nothing.
#7 - You have too much research to do. PSI means nothing.
99siky
Aug 31, 2011 02:00 PM
99siky
Engine Management and Tuning
Aug 15, 2011 05:57 PM
99blue_si
May 8, 2007 04:59 PM
Civicvtihatch
May 19, 2005 07:58 AM
