HELP bolt for top hat is stripped
Old Aug 13, 2011 | 09:22 AM
ev94eg's Avatar
Default HELP bolt for top hat is stripped
the alan head that takes the top hat off of the strut stripped out while under alot of pressure when i was taking it out and now im stuck in my driveway with my car on jacks ... how can i get the bolt off of where the alan head is so i can get the spring off and put my new coils on there ?
Old Aug 13, 2011 | 09:29 AM
grumblemarc's Avatar
The Grumpiest
Default Re: HELP bolt for top hat is stripped
Easy. Vice grips up high on the shock piston near the top hat.
Old Aug 13, 2011 | 09:37 AM
ev94eg's Avatar
i tried that first and not enough room to fit in there heres a pic
ahd where the nut is at the top the alan head inside of it stripped during the process
Old Aug 13, 2011 | 09:50 AM
98civdx's Avatar
Master Detailer
What do you mean there isn't enough room? I've done it many times. I have to do it on both of my rear shocks.
Put vise grip on the piston, put vise grip on the ground, step on it, and turn the nut untill it comes off.
Old Aug 13, 2011 | 09:53 AM
ev94eg's Avatar
alright let me try again. ill let you know if it works
Old Aug 13, 2011 | 09:57 AM
Dontoh's Avatar
you might have to hold the strut so it doesnt spin
Old Aug 13, 2011 | 10:02 AM
ev94eg's Avatar
yea ive been having to do that im coolin off for a minute and then going back out to give it a try
Old Aug 13, 2011 | 10:05 AM
Dontoh's Avatar
smart man :p
Old Aug 13, 2011 | 10:06 AM
ev94eg's Avatar
yea the humidity here in TN is out the *** its hot as hell
Old Aug 13, 2011 | 10:16 AM
The Grumpiest
I know. Clamp that bitch on there tight. Lay it down on the ground to keep the vice grips from turning.
Old Aug 13, 2011 | 10:18 AM
ev94eg's Avatar
somehow the bolt is still spinning with the alan head still after trying like 3 diff ways to vice grip it
Old Aug 13, 2011 | 10:22 AM
The Grumpiest
Are you putting the grips on the piston through the coils? And you hafta clamp that thing on hard. Almost to the point you can't lock it down.
Old Aug 13, 2011 | 10:28 AM
ev94eg's Avatar
yes but see my piston still has the black covers on them and thats why
Old Aug 13, 2011 | 10:40 AM
Wrona's Avatar
that happened to me when i was doing a celica so i just used my air gun and it took it right off
Old Aug 13, 2011 | 10:41 AM
The Grumpiest
The dust shield is in the way. You really need to get it clamped on the piston proper. That won't work.
Old Aug 13, 2011 | 10:43 AM
ownedevo10's Avatar
you will have to push the rubber cover up so you can get a better grip on the piston...just slide the cover up and let us know how that works...
Old Aug 13, 2011 | 10:45 AM
ev94eg's Avatar
its not rubber its metal.... saw zaw lol
Old Aug 13, 2011 | 10:46 AM
The Grumpiest
That black piece is metal? How does it allow the piston to travel then? How are you even getting the vice grips on it?
Old Aug 13, 2011 | 10:56 AM
ev94eg's Avatar
yea its metal and not sure but they were traveling lol..and it bent the metal once i put all my strength into squeezing the vice gripz
edit: now that i think about it i dont think they were traveling cause it rode to shitty for a nice setup it had
Old Aug 13, 2011 | 03:22 PM
ev94eg's Avatar
well finally got it off.. involved a little torching.
Old Aug 13, 2011 | 11:06 PM
boostedef123's Avatar
what part of tn you from?
Old Aug 13, 2011 | 11:39 PM
ev94eg's Avatar
tullahoma ... bout an hour and a half or a little farther down south of nashville
basically the town right eside where bonnaroo music festival is
Old Aug 14, 2011 | 06:03 AM
Ah right in the middle of no where lol.
Old Aug 14, 2011 | 01:31 PM
ev94eg's Avatar
yea its a littl peaceful town ... u from tn
Old Aug 14, 2011 | 04:34 PM
The Grumpiest
Anywhere is TN is in the middle of nowhere.
