1991 CRX SI Dash in 1990 EF SI Hatch PHOTOS - Will this work ?
Old Aug 13, 2011 | 06:56 AM
nickelz34's Avatar
Default 1991 CRX SI Dash in 1990 EF SI Hatch PHOTOS - Will this work ?
Ok i just pulled out my ef dash and i got hooked up with a perfect dashboard from a 91 crx si.
The dashes look identical its just got a small differance here or there .
Heres some pics of the dash i got and the dash i had below
Old Aug 13, 2011 | 07:36 AM
nickelz34's Avatar
Default Re: 1991 CRX SI Dash in 1990 EF SI Hatch PHOTOS - Will this work ?
they look about the same
Old Aug 13, 2011 | 08:03 AM
BlendedEM1's Avatar
why did you take it out looked good from what I could see and it should work
Old Aug 13, 2011 | 08:05 AM
nickelz34's Avatar
the two pics on top are the old dash in the car the two on bottom are the two pics of the new dash .
Im guessing your thinking i took out the nicce dash on the ground lol .
Old Aug 13, 2011 | 08:06 AM
nickelz34's Avatar
the old dash has broken pieces and it was painted about 50 diff colors over the course of owners this car has had
Old Aug 13, 2011 | 08:11 AM
BlendedEM1's Avatar
Oh ok I see it now and yeah they should be interchangeable as far as I know
Old Aug 13, 2011 | 08:15 AM
uptownx24x's Avatar
It will work. You can also put in an integra dash. If you search for it you will find tons of people that have done it
Old Aug 13, 2011 | 11:07 AM
wreckin-rex91's Avatar
The dashes are very similar and it will work no probs. What you will also need is the crx center console and lower dash plastics. You would probably want the metal under supports for the crx also as the crx center console is more of a driver wrap around set up.
Old Aug 14, 2011 | 03:31 AM
91ef_civic's Avatar
okay i have this done in my car it swaps right over all you need to do is to change the metal piece that is on the floor where the dash was held to ( 2nd pic basically under the radio ) you have to use the CRX one. you will also need to cut the carpet a little bit for it to fit perfectly. if you dont do this the bottom of the dash will move and that is not something you want. the more support the better believe me! GL with the swap. and the CRX dash looks much cooler then the stock hatch dash IMO
Old Aug 15, 2011 | 10:51 AM
nickelz34's Avatar
just got meh dash in guys ill have pics up tonight of the install . it was really great ! everything swapped over and i do have the si crx piece that goes in middle (havent put it in yet i think i am going to have to take the dash back out to mount the metal piece on first )
Old Aug 17, 2011 | 11:02 AM
nickelz34's Avatar
ok guys here is the finished pics of the install
dash fits real nice !
heres some pics :
Does anyone know where i can get the dash piece that goes were the drivers knees are ? It covers all the wires from the ignition and fusebox .
I snapped a pic of it so you could all see the missing piece .
Also i need the rest of the dash for the 91 crx si , the other part im missing is the plastic bezel that goes around the radio and the climate controls.
Old Aug 17, 2011 | 11:07 AM
4drEF's Avatar
Keyboard Humorist
The sticky For Sale/Want to buy post at the top of this forum, the classifieds section on this site, craigslist, eBay, dismantlers, etc.
Some wrecking yards have sites on the internet that you contact and request parts through.
In your tech post is not the right place.
Old Aug 17, 2011 | 11:44 AM
nickelz34's Avatar
"In your tech post is not the right place. " <<<< Im not understanding your wording here when you said this . Do you mean i posted this in the wrong place ?
Thanks for the help on finding parts for the EF I will check out some of those links
Old Aug 17, 2011 | 01:07 PM
Hooptie2's Avatar
The 91 CRX dash will work in the 90 hatch. The 88 and 89 are different from the 90 and 91. A dash from a 88 or 89 CRX will work in a 88 or 89 hatch. Have fun and you will have to make a few holes. Sorry I dont have pics of the install, we did it to one of my friends hatch's.
Old Aug 17, 2011 | 06:36 PM
nickelz34's Avatar
Im done with the dash , didnt have to make any holes to get it to go in . Unless you mean i would have to make holes for the 88- 89 models .
Old Aug 18, 2011 | 07:53 AM
4drEF's Avatar
Keyboard Humorist
Check out #1 in this post
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/%2A%2A%2A-crx-ef-civic-technical-forum-rules-%7C-trial-user-info-%2A%2A%2A-2086185/
Old Aug 19, 2011 | 08:51 AM
nickelz34's Avatar
oo ic lol i went ahead and posted it in the sticky
Ef9vsDa9
13
Jan 1, 2010 03:07 PM
lance_dc2
Jul 9, 2009 09:59 AM
scuffywin
Jun 28, 2007 12:51 PM
Japan
Jul 27, 2006 01:52 AM
