stock b16 rods 9,500 rpm??
Old Aug 12, 2011 | 05:59 PM
bradabu's Avatar
Default stock b16 rods 9,500 rpm??
i got a b16 with skunk2 pro 2 cams, pro series valve springs and retainers. skunk2 IM and hitch headers. i also got high comp pistons and ACL race bearings (main and rod)
with this setup what rpm range will i make power to??
and with stock rods, how high can i rev up to?? im gonna get ARP rods bolts and head studs.
thanks
Old Aug 13, 2011 | 11:45 PM
Red_Army's Avatar
Default Re: stock b16 rods 9,500 rpm??
revv as high as it'll go. keep revving.
when you see a rod like object shoot from your hood. thats how high you can rev it and when it'll stop making power.
dynos aren't just for show.
Old Aug 15, 2011 | 09:12 AM
da_infamous_EM1's Avatar
how much do u want for it lol ill rev it for u
Old Aug 15, 2011 | 10:09 AM
West Werks's Avatar
I think I just sharted....
That might be the funniest post I have some in quite some time...
Signature worthy if HT still allowed them.
Old Aug 15, 2011 | 11:04 AM
Garage 808 Hatch's Avatar
You did all that work to the motor, and left the stock rods in it? Did you at least put in ARP rods bolts?
Old Aug 15, 2011 | 11:19 AM
Wdbjr12345's Avatar
i reved mine to 9800 for a whole year till i decided to build somthing bigger
Old Aug 15, 2011 | 04:15 PM
JDMEMone's Avatar
i think that little engine is a little over cam'd. I made power to 11k with a B16 bottom end and pro 1 cams. but my bottom end was built. 9500 on stock rods will hold if you have the rod bolts.
Old Aug 15, 2011 | 05:35 PM
.Manny.'s Avatar
Touching My Member
Dyno sheet or I call Shenanigans.
Old Dec 20, 2011 | 03:46 AM
exgr's Avatar
Homosexual by choice
stock b16a rod is super beefy and way over built. out of all stock B series it is the strongest "stock" rod.
Old Dec 20, 2011 | 11:09 AM
exgr's Avatar
so what was the whp and ft-lbs @ wheels? care to share the graph?
Old Dec 20, 2011 | 11:58 AM
hondasdohc's Avatar
My f20b revved up to 9k made power all the way to it too. Beating that motor for 3 years now that block can take some abuse but b16b's can definitely take some 9500 rpm revs too that's what they are made for. The rod/stroke ratio gives it the reliable 9k revs but no torque
Old Dec 21, 2011 | 07:16 PM
mikesrex's Avatar
I rev my stock B16A bottom end to 9500 with no issues at all. I've had the motor apart twice for inspection and the rod bearings look fine. This is on my turbo integra by the way. Not quite sure on the WHP but it has gone high 11's weighing in over 2700 lbs the last time I took it to the track.
Old Jan 19, 2012 | 05:42 PM
xero_xero's Avatar
I am really looking for midrange power. i was thinking a good track cam, toda is the name i keep seeing, posibly a jun cam. I have a set of S2p2 cams and 2 complete swaps that are bone stock. i have the springs and a nice set of valves to beef it up as well.
My question is how will this perform on a stock motor (with adequate springs and retainers)
Old Jan 20, 2012 | 07:07 AM
00Red_SiR's Avatar
All Motor Mentor
Way to much cam for a motor/build like yours. Look at the toda A cams or the buddy club 3's. The only "weak" b series rods are the LS rods. Stock b16 and 18c rod bolts are just as strong as Arp bolts.
Old Jan 20, 2012 | 11:49 AM
FlewByU352's Avatar
I wouldn't say it's the rods being the weakest link as much as the bolts. Even then you need more stiffening besides a stock girdle to be considered safe IMO. I wish I could find the video but you would all be amazed how much metal stretches at higher RPM's.
Old Jan 22, 2012 | 09:40 AM
murcar94's Avatar
9000 rpm at most!!..unless u want a hole in ur block :D
Old Jan 23, 2012 | 05:46 PM
maikito's Avatar
you can rev 9.5k completely stock bottom end no problem at all..
Old Jan 23, 2012 | 06:11 PM
92civiceg9gsr's Avatar
It will be just fine. If your really worried get some arp rod bolts. I would be more concerned with turning that high without an ATI damper.
Old Jan 24, 2012 | 01:35 PM
Colman787's Avatar
i won't rev that high without arp rod bolts, i think that will be your weak point
Old Jan 24, 2012 | 07:26 PM
maikito's Avatar
not really, our stock bottom end b16 revs 9.5k everyday "and i do mean everyday" and has no problm at all
Old Jan 24, 2012 | 07:35 PM
maikito's Avatar
LOL "dont matter how many times i read this, i still
Old Jan 26, 2012 | 04:55 AM
wolve's Avatar
stock gsr/itr does 9500 rpm all day
stock b16 is fine at those levels
with arp's i'd take it up to 10k
Old Jan 26, 2012 | 06:59 AM
guachi1209's Avatar
LMAO!!!!!!
Old Mar 25, 2012 | 11:11 PM
exgr's Avatar
my recent b16a dyno.
Old Mar 26, 2012 | 01:34 AM
peter_b16's Avatar
i was stupid enuf to test my first obd0 91 b16 and tried to see how high it can rev..floated 2 valves at 11k..rods were perfectly fine from wat i remember..never tried it again so i cant say for others..
