Harness question
Old Aug 12, 2011 | 04:00 PM
boostNjuice's Avatar
Default Harness question
I just put a OBD0 Integra DA motor into my 88 crx SI. the harness that was on that motor would not work with the car because it had clips that didnt even exist on the car.
heres the story i bought the crx with a LS motor that has rod knock, then i got a donor motor from a teg, it came with a harness too but it wont work on the crx. i thought all OBD0 harness's were teh same. anyways I do have the harness that originally came with that crx it did work but it was really really shitty spliced/wires ripped hanging etc.. so i did some repairs to it but now im just having a difficult time determining which plug goes to what sensor since its all just chopped modified. i peeled back the loom so i can see the original wire colors and hopefully someone can tell me what wire colors go to which sensor and what not, keep in mind im not really even sure what harness i have i just know that it plugs in and runs.
Old Aug 12, 2011 | 05:14 PM
crx_si-r's Avatar
Default Re: Harness question
use the stock harness that came with the crx. which sensors/plugs are you getting confused?
Old Aug 12, 2011 | 06:09 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
There are several different harnesses for OBD-0 cars... Civic/CRX DX/STD, Civic/CRX Si, CRX HF for starters... Let alone Integras, Preludes, Accords, ect.... Essentially you always use the engine harness for the vehicle you have (Not for the engine) and modify it as needed. Figuring out the sensors is easy... If it runs just lable them as you pull them off and repair as needed. Some wires are the same color so it really isn't going to help a lot unless you take the time to probe...
Old Aug 13, 2011 | 12:34 AM
yea but i need like wire color pinouts i think im missing the map sensor its either the map or TPS i cant figure out which 1 is missing cuz i only have 1 3 wire connector thatl attach to either tps or map. anyone know where i can pull up a diagram of the wire colors of like the CRX SI diagram?
Old Aug 13, 2011 | 05:22 AM
crx_si-r's Avatar
your not missing it. on all 88-91 civic/crx cars the map sensor wiring is not part of the engine harness, its part of the main harness. the TPS is part of the engine harness
Old Aug 13, 2011 | 05:36 AM
turbohatchBnuts's Avatar
here you go just search on google 0bd0 pinout diagram
if i was you i would go to the junkyard look for 88-89 crx si or 89 civic si engine harness. after you find one label it as you take it off.
Old Aug 13, 2011 | 12:41 PM
lols o ***. wait so is ti attached to the car's harness?
Old Aug 13, 2011 | 12:56 PM
DO IT ON ALL FOURS
Yes, under the hood coming from the passenger shock tower. The TPS is on the engine harness with Green, Red, Yellow wires... (if memory servers the stripes are white, blue, white respectively).
Old Aug 13, 2011 | 12:58 PM
DO IT ON ALL FOURS
Unfortunately, most of these do not match the plug side (on engine harness) when it comes to colors...
Old Aug 13, 2011 | 01:03 PM
why the hell am i not seeing **** man.
Old Aug 13, 2011 | 01:05 PM
also is this the wiring for the map (if memory servers the stripes are white, blue, white respectively). incase the clip is cut off
Old Aug 13, 2011 | 04:31 PM
DO IT ON ALL FOURS
You need to learn how to read... I said the MAP comes off the shock tower... The TPS wiring is from the engine harness. The colors of the TPS wires should be Green with a white stripe, Red with a blue stripe, and Yellow with a white stripe... I am too lazy to look at one of my cars right now to tell you all the exact colors... Why don't you post pictures and we can help you better. My cars aren't hacked so who knows what they did to your stuff.
Old Aug 13, 2011 | 05:23 PM
crx_si-r's Avatar
Send me money and I will build you a brand new harness with labels.
;p
Old Aug 13, 2011 | 09:59 PM
;p
no need, found the map sensor .. the ******** cut it off at the fire wall i had the extend new wires and solder a new connector! all good now
johnnan71
Mar 11, 2015 04:43 PM
HonDelso
Aug 2, 2008 12:50 AM
BlakeJ53
Sep 5, 2007 05:16 AM
spettinger
Dec 11, 2002 02:02 PM
