97 Prelude - Fully Built $7k W/ Turbo (break-in tune na right now)
Old Aug 12, 2011 | 11:04 AM
KTULU990's Avatar
Default 97 Prelude - Fully Built $7k W/ Turbo (break-in tune na right now)
SALVAGE TITLE
I've spent over $20k getting this car to where it is.
*******As of right now it has a break in tune (non-turbo) *******with about 250 miles on new engine trans and most other parts. **********
I have every receipt. This was built to make big power (650+whp).
Looking for $9k
Lowest I will go is $7k with the turbo parts. If you want the car without the turbo stuff $5500. I am firm on these prices.
$5000 firm for the car $6500 with turbo stuff
Stats:
Engine:
Sleeved Block
Crower Rods
Cp pistons w/ upgraded wrist pins
Power Enterprise Kevlar Timing Belt
Golden Eagle Head Gasket
Kaizen Speed Balance Shaft Eliminator Kit
Head:
Skunk2 Pro 1+ cams
S2 cam gears
S2 Valves
S2 Pro Valve Springs w/ Seats
S2 Retainers
S2 Intake Manifold
Professional Products 68mm Throttle Body
Hondata Intake Manifold Gasket
Golden Eagle Cam Seal
Trans:
SynchroTech Carbon Coated Synchro kit (Manual Transmission Bearing, seal, and Synchro kit with springs and top and bottom bearings for both shafts)
Mfactory LSD and Diff Bearings
Competition Clutch Twin Disk
P-Spec Adjustable Short Shifter
S2 Shift ****
Fueling:
Walbro 255lph Fuel pump
Bosch 044 fuel pump
AN Stainless fuel lines
Injector Dynamics 1000cc Injectors
Fuel Pressure Regulator
AEM Fuel Rail (Red)
Aeromotive Fuel Pressure Regulator
Ignition:
M&W Pro-10 Kit
Crane PS92 coil
Custom wire harness
Turbo System: (Please note that these parts are not currently installed)*****
Borg Warner S362 Polished (Ceramic Coated / Powder Coated Candy Red)
BF Fittings AN Oil Feed/Return Line Kit (black)
BF Fittings Catch Can with Drain Back (Polished)
Blaast Performance Sidewinder Manifold (Jet Hot Coated)
Blaast Performance 3” Down Pipe
Tial 44mm Waste Gate
Tial 50mm Blow off valve
Engine Management/Gauges:
Hondata S300
Boost Control package
4 Bar Map Sensor
OBD2-OBD1 Harness
AEM Gauges
Boost
Wideband
Fuel Pressure
Oil Pressure
Loteck 3 Gauge Vent Pod
Autometer Single A-Pillar Pod
Cooling:
Mishimoto Radiator (2 Rows)
Mishimoto Radiator Shroud with 2 slim fans
Samco Radiator Hose Kit
Other:
Innovative Motor Mounts (Race)
Aerocatch locking hood pins
Alpine head unit (high end)
Hondata 4 Bar Map Sensor
Golden Eagle Oil Sandwich Plate
Auto to Manual Timing Belt adjustor Conversion
Old Aug 17, 2011 | 06:13 AM
KTULU990's Avatar
Default Re: 97 Prelude - Fully Built $7k W/ Turbo (break-in tune na right now)
bump
Old Aug 23, 2011 | 02:42 PM
KTULU990's Avatar
ttt
Old Aug 23, 2011 | 05:21 PM
Andrew3379's Avatar
WOW good deal
Old Aug 26, 2011 | 08:16 AM
KTULU990's Avatar
Thanks. If I don't get someone in the next month I'm going to part it out. I did some math and I can make at least $9k + the rolling chassis.
That being said I would much rather get rid of it all in one piece and save myself the hassle
Old Aug 29, 2011 | 04:00 PM
KTULU990's Avatar
BUY ME!!!
Old Sep 3, 2011 | 12:13 PM
KTULU990's Avatar
ttt
Old Sep 7, 2011 | 05:00 AM
KTULU990's Avatar
bump...
Old Sep 10, 2011 | 11:21 AM
KTULU990's Avatar
ttt..
Old Oct 14, 2011 | 02:57 PM
KTULU990's Avatar
Still have it in one piece. Most likely until at least next weekend.
Old Dec 23, 2011 | 05:12 AM
KTULU990's Avatar
ttt
Old Jan 1, 2012 | 03:52 PM
KTULU990's Avatar
ttt
Old Jan 3, 2012 | 03:54 AM
goldhatch94's Avatar
so what is the deal here? you say at the top salvage title and you show a car report that shows no salvage title..
Old Jan 3, 2012 | 06:07 AM
KTULU990's Avatar
I ran the vin as you can see and it came up clean. Someone else ran the vin with another more expensive service and it came up that it was totaled with 300 some odd miles on it. If you ask me it was prob stolen but idk for sure. The car drives straight and until that person let me know i had no idea. So as soon as i found out i lowered the price and let everyone know. Im def not trying to hide anything at all. This is a great deal no mater what. Let me know if you have any questions.
Thanks
Matt
Old Jan 4, 2012 | 03:22 AM
KTULU990's Avatar
ttt
Old Feb 1, 2012 | 10:06 AM
KTULU990's Avatar
ttt...
Old Feb 13, 2012 | 11:36 AM
KTULU990's Avatar
ttt...
Old Feb 15, 2012 | 04:04 AM
KTULU990's Avatar
bump
IAluder95
Jun 9, 2012 11:25 AM
slick1851
May 29, 2010 10:48 AM
hOndACraZee
Northwest (Sales)
May 28, 2010 11:52 AM
turbociviccoupe
Sep 30, 2006 08:38 PM
