I need help with a 1990 civic
Old Aug 12, 2011 | 07:31 AM
max323's Avatar
Icon6 I need help with a 1990 civic
I replaced the engine, car started and runs for 45sec. to a min. and a half ok, then startes balking down and backfiring through the fuel injection system, will not accelerate. Timing checkes OK. Has normal fuel pressure.
Old Aug 12, 2011 | 08:31 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: I need help with a 1990 civic
Well for starters you need to actualy give us some more information...
What engine is it?
Are you DPFI or MPFI?
Are you OBD-0 or OBD-1?
ect, ect, ect...
The more information you give the better we can help you.
Old Aug 23, 2011 | 05:45 PM
max323's Avatar
I am sorry I am not informed enough to answer those questions. The engine is a 1.5L. I have replaced all the censers, and the distributer. The only thing left on the engine that is not new is the throttle body. The car is running much better now. It does perfect until it warms up and the fans kick on, at that point it starts the choking out mess again. there is a vacuum line that goes in by where the throttle cables connect that if clamped off makes the car run even after it has warmed up but it will not idle below 3k when that is done. Any leads as to where to look from here would be helpful.
Old Aug 23, 2011 | 08:52 PM
nickelz34's Avatar
have you tried adjusting the idle on throttle body ?
also look on the front of your engine and tell us if it says its a d15 . it most likely is a d15 but on the engine it will say d15y7 or d15y8 for example . the type of motor is also printed on your cam gear cover on a sticker on the right side of the engine .
any pictures ? videos help better if you can up one to youtube
Old Aug 24, 2011 | 05:48 PM
max323's Avatar
We have adjusted the idle with no luck. The numbers on the engine are (D15B1043526) and the ones on the cam gear cover are (NGKBCP6E-11)
Old Aug 24, 2011 | 06:05 PM
nickelz34's Avatar
Does check engine light come on after it starts running like **** ?
Have you had the OBD checked at a autozone or advanced auto ?
Who did the engine replacement ?
Old Aug 24, 2011 | 06:23 PM
DO IT ON ALL FOURS
Kid we get it, you are desperate to up your post count... but you are saying stuff that is just going to get the OP confused and misguided. Also a D15Y7/8 eh? Mildly entertaining...
OP - there are multiple vacuum lines going to the intake manifold. Your description of this insanity is horrible... I understand you obviously have no clue about engines and probably shouldn't be messing around under the hood, but for us to help you, you NEED to describe things to us. Unless you post pictures or a video as mentioned before, what you are describing is all too over the place to be of service.
One of the most helpful things you could do is let us know if you are Multiple-Port of Dual Point Fuel Injection. I assume Dual Point... You say timing is good, fuel pressure is good, and all sensors and the distributor was replaced... there isn't much more going on. The throttle position sensor could be a possibility, but you say it runs fine until the fans kick on. Which makes no sense... unless the added electrical load is causing problems or something of the sort.
Old Aug 24, 2011 | 06:49 PM
turbohatchBnuts's Avatar
so does your check engine light come on or not?
Old Aug 24, 2011 | 07:24 PM
max323's Avatar
I have done a lot of reading on the TPS and it sounds like it is out of calibration. I am going to check that and reply with the results.
Old Aug 24, 2011 | 09:14 PM
nickelz34's Avatar
ya you dont have to be a ***** bra
N3va3vaSatisfi3d
i was just asking him a question and i think it could have been easily understood
as for the d15 y7 / y8 i misread it and thought he said d16 so there is a slight typo there .
and im not a kid lol neither am i trying to troll the forum getting meh post count up lol
63 posts since i joined in 2008 ? < how does this make me trying to get my post count up that says ive been here for 3 years lol
op did you find anything else out ?
Old Aug 25, 2011 | 06:07 PM
if it was out of calibration your check engine light would come on code 7
PaulR3
Honda Ruckus and Scooters
Oct 6, 2016 02:38 PM
Goodaddy
10
Jun 8, 2009 11:55 AM
Hardedge
May 16, 2009 07:38 PM
