budget b18c1 build
looking for comments on my build good or bad
my budget is $2500 "not including machine work"
goal: 200whp and reliable
setup so far:
b18c block hot tanked and bored .020 over
nippon b16a pistons .020
arp rod bolts
arp head studs
2 layer gasket making my setup 11.2:1 cpr
b16 head mild pnp hot tanked 3 angle valve job new valve guides
supertech valvesprings
itr cams
blox intake manifold
65mm throttle boddy
440cc injectors
rmf narrow rep header
gsr tranny with b16 1st thru 4th and ls 5th with a obx lsd
p28 tuned on crome
my goal is 200whp but keep in mind this is my daily driver i dont need 200whp as long as its fun to drive and reliable i will be very happy with the setup just looking for any advice on the setup.
setup so far:
arp rod bolts
arp head studs
itr cams
65mm throttle boddy
440cc injectors
p28 tuned on crome
EMS is not necessary. Running a factory ECU with a chip program is just fine especially with your goals. Crome will do. Looks like a nice setup, but id look into some cams. Anything other than OEM cams will do your build tons of justice.
he can do more with spending that cash on other stuff
so what you're trying to say is you have the setup you described and want 200whp and have 2500 to spend. or you don't have anything and this is your plan to spend your 2500?
ive spent around 2500 on this setup this is whats goingin my car rite now im hoping its gunna make 200whp jw wha tu guys think it will make i am not changing anything yet next spring i plan to upgrade cams and get a better tune but this is my setup rite now
Crome is fine for that setup. 3inch exhaust is more "free" power, but i understand the dd part and being loud. And anything around 185-190whp NA is definitely fun in a slightly lightened chassis..! Cams slightly larger than ITRs could get you to 200whp on that setup with a 2.5" exhaust, im almost sure of that.
I wouldn't get so set on a whp goal....dyno's can either be heartbreakers or fat-head makers. My buddies ITR dyno'd at 198whp and 131tq and is slower than my car that dyno'd at 177whp 124tq. He was on a dynapak open header and I was on a dyno dynamics which read on average 5-7% lower with full cat-back (apexi ws2). Opened up my car makes right at 187whp and 126tq. Havent been down the 1320 recently. Set an ET and MPH goal...more fun to chase and more measurable realistically. Looks like a very nice build though, similar to mine.
I would have definately picked up the edelbrock performer intake and a portmatched TB over the blox piece...I would almost bet 8-10whp gain with a proper tune. That is my next upgrade.
Very true about the dynos.. All of the dynojets in my area read within 3-4whp of eachother.. So im lucky there. But so right about dyno numbers, and especially when you get to comparing mustang dynos to dynapacks etc, numbers will be very scued.. Just knowing the weight of your car, and what gearing your using and then just running it down the 1320 can tell you alot. And i like that part about a Gutted interior integra OP
boostedcb7
Sep 9, 2008 04:49 PM
LSVTEC ReX
25
Aug 25, 2006 06:33 PM
LSracing94
22
Mar 24, 2006 12:01 PM
