CAR WONT START AFTER BUILD!!!!
Old Aug 11, 2011 | 02:06 PM
bowtieboy911's Avatar
Icon3 CAR WONT START AFTER BUILD!!!!
i just recently got my b16 completely built and i got it back put it in the car and got it all ready and went to crank it over and it cranks over but wont start and when its cranking it kinda makes a whining noise and also makes like a clicking noise not fast and constant it like click..click..click..click when its turning over sounds like its coming from the head? my fuel pump turns on and i have fuel pressure, im getting spark but havent really messed with ignition timing? i havent checked my fuel filter but it could be so clogged it wont start right? i thing it is more than likely a timing issue...they were supposed to time it but they could have forgot to do it...i would just like to know if anyone has ever came across this or can help me out???
Old Aug 11, 2011 | 03:01 PM
exb18c1's Avatar
Default Re: CAR WONT START AFTER BUILD!!!!
Who built a motor for you? A shop or a friend? What kind of mods are done to the motor?The clicking noise is definately not good!I hope you didn't bent the valves!Remove the valve cover and check the timing.Give us some news!
Old Aug 11, 2011 | 03:15 PM
Icon3 Re: CAR WONT START AFTER BUILD!!!!
a local machine shop he does all kinds of motors and i got it bored sleeved rods bearings skunk2 pro 1 cams ferrea valvetrain kit comes with springs retainers seals spings locators etc everything you need but im deffinately worried i bent a valve but i took my car there after i put the motor in and it wouldnt start to have them take a look since they built it but idk if anything should come close the the valves but im not sure...
Old Aug 11, 2011 | 04:43 PM
civickiller's Avatar
do a compression and leak down test
Old Aug 11, 2011 | 05:28 PM
exb18c1's Avatar
Do you have adjustable cam gears?Definetly check compression.I wouldn't check too many things because after the shop will say that you are the one that did it.Take it there as fast as possible.
Old Aug 11, 2011 | 08:36 PM
yes i do have adjustable cam gears
bowtieboy911
12
Aug 14, 2011 06:02 PM
Nooch
Dec 24, 2010 05:36 AM
dan89crxsi
Feb 10, 2007 02:44 PM
civicturbo22
Jan 25, 2005 05:43 AM
bonestock92si
38
Aug 30, 2004 10:02 PM
