Mid-Atlantic (Sales) VA, DC, and MD
DE - FS: LS Swapped 94 EG Coupe - $1900
Old Aug 11, 2011 | 07:19 AM
Ostrich2.0's Avatar
Default DE - FS: LS Swapped 94 EG Coupe - $1900
My 94 Civic coupe. 225k miles on the body. About 20k on rebuilt engine. Got the car with a B18A1 Ls motor with YS1 trans a little over a year ago, built it at ACA performance in Newark,DE with high compression eagle rods and 11:1 forged probe pistons and full gasket set a few months later. Was planning on going a high compression/low boost build but funds were low after the motor was built so i decided to just leave it all motor. Have receipt for engine work totaling $2500 which included the tune. Recently replaced alernator, battery, oil pan and gasket, clutch and flywheel. Tagged until next summer. Has a sunroof, works most of the time, sometimes sticks but always opens and closes and does not leak. Has the catalytic converter so it will pass inspection no problem.
Lowered on springs.
14" Motegi Wheels
2.5" Exhaust
CTR Front Lip
Hasport Trans Mount
K2 Motor Smoked Amber Corners
AEM Short Ram Intake w/ 3" Blox filter and Velocity Stack
Type R Style Header
330cc H22 Injectors
Chipped P75 ECU, Street tuned by ACA Performance in Newark,DE
Fresh Clutchmaster Stage 2 Clutch and 10lb Clutchmaster Flywheel
Has crappy paint job that i unfortunately attempted to do myself and minimal surface rust. Has 2 dents, one above drivers side rear wheel well and next to the passenger side sidemarker. Transmission grinds third and occasionally second, but goes into gear no problem. Probably needs rotors since it has a bit of vibration when hard braking. Needs Alignment. Just put on new passenger side brake pads, drivers side need replacing but they will come with car. Passenger side window needs the window regulator and and window stich. I took it off the mount so you can manually move it up and down, does not leak or fall. No Check engine lights or burning oil. NO A/C or P/S.
I have a low mileage YS1 replacement transmission with linkage that will go with the car ..... cost me 350.. I dont have the time to swap it in right now. It doesnt grind or have any popouts, i took it out my buddies EF when he swapped in a GSR.
I also have a brand new unopened gallon of paint and reducer of the viper blue paint incase you want to respray the car or have someone do it for you. Also comes with half a gallon of high build 2K primer and half a gallon of urethane viper blue paint and medium reducer. the paint, primer, and all accs. I bought will also come with the car. All the paint and accs. totaled me about $500.
text me at 302-339-0162 for info. Thanks!
Please come see the car before you satrt talking money. I would rather not waste your time or mine.
Located in Lower Slower Delaware Near Rehoboth Beach.
Old Aug 11, 2011 | 03:25 PM
mike739wrxr6's Avatar
Default Re: DE - FS: LS Swapped 94 EG Coupe - $1900
bump
Old Aug 12, 2011 | 06:25 AM
Ostrich2.0's Avatar
thanks!
Old Aug 12, 2011 | 01:49 PM
Ostrich2.0's Avatar
bump
CCMPREZ
Jul 24, 2017 09:34 AM
J4k3
Jun 19, 2006 07:05 AM
jerzygrll609
Sep 12, 2005 03:32 AM
Coupe d 'Etat94
Nov 9, 2003 11:14 AM
