D15B2 pulleys on D16z6?
Old Aug 10, 2011 | 09:48 PM
Emacie272's Avatar
Default D15B2 pulleys on D16z6?
I am swapping to a D16z6 in my EF and there is an engine I found for sale for a good price for what it is. But it doesn't have a crank pulley and no cam gear. Is one or both interchangeable?
Old Aug 11, 2011 | 06:14 AM
KINGVEM^^ED6's Avatar
Default Re: D15B2 pulleys on D16z6?
no
Old Aug 11, 2011 | 12:34 PM
24TEN's Avatar
PHANTOM MENACE
^Are you sure? I could've sworn all 88-95 camgears are one and the same and the crank pulleys, although slightly different in design, still have the same timing marks and are interchangeable between DX/LX/EX/Si...
Old Aug 11, 2011 | 12:37 PM
Ef has that little piece to keep pulley on the crank forgot what its called the rest don't I wouldn't do it but hey its not my car go to the junk yard n grab one
Old Aug 11, 2011 | 12:39 PM
24TEN's Avatar
PHANTOM MENACE
Key?
Old Aug 11, 2011 | 12:42 PM
YeaH
Old Aug 11, 2011 | 12:50 PM
http://www.homemadeturbo.com/showthread.php?t=52375
Old Aug 11, 2011 | 01:06 PM
24TEN's Avatar
PHANTOM MENACE
^interesting. I'm going to compare my spare pulleys when I get home.
Old Aug 11, 2011 | 01:12 PM
jlicrx's Avatar
88-91 D15B1 and D15B2 have a 22mm diameter front crankshaft snout and use a 3 rib alternator belt
88 D16A6 has a 22mm diameter front crankshaft snout and uses a 3 rib alternator belt
89-91 D16A6 has a 24mm diameter front crankshaft snout and uses a 3 rib alternator belt
92-95 D16Z6 has a 24mm diameter front crankshaft snout and uses a 4 rib alternator belt
D15B2 crank pulley will not fit D16Z6 crankshaft
Old Aug 11, 2011 | 09:23 PM
nitewolf's Avatar
i have a d15b2 or b1(forgot which one) on my z6 you have to use a smaller woodruff key. im pretty sure i used the b2 one and not the z6 key. have pic if you dont believe.
Old Aug 11, 2011 | 11:09 PM
Canadian_EF's Avatar
I am curious of this. I heard it was bad because of some harmonic dampener in the pulley on the z6/y8, but nobody really knew for certain.
Can anyone shed some light on this? I have a B2 pulley, and it is so nice and light compared to the y8 pulley... not a big gain, but a free gain none-the-less.
Is it really that bad if it can be done?
nitewolf, post up some pics!!!
donvito#1
Dec 17, 2011 05:01 PM
driveslow
Apr 20, 2009 03:00 AM
crxblues
13
Apr 6, 2009 04:47 AM
JohnnyB70
Sep 5, 2004 03:53 PM
