whats up with the stick vibration on tegs ?
Old Oct 3, 2002 | 07:57 AM
RacerXintegra2k's Avatar
Default whats up with the stick vibration on tegs ?
Is it just mine or does the shifter vibrate alot more than normal ? especially when i turn on my ac
Old Oct 3, 2002 | 08:17 AM
vtec69's Avatar
Default Re: whats up with the stick vibration on tegs ? (RacerXintegra2k)
my friend had that problem
it turned out to be a loose exhaust bolt
Old Oct 3, 2002 | 08:54 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Alot more than normal compared to what? My shifter vibrates tons more than the shifter in my old car (89 Camry), because Integras have solid linkages while the Camry had a cable linkage (Camry shifter did not vibrate at all).
Old Oct 3, 2002 | 10:18 AM
GSR-REX's Avatar
New User
Mine started to vibrate hella more when I put prothane bushings on it. I asked if that was normal with stiffer bushings and people said "yes"...so I took one of them off (rear one). At redline shifts I was barely able to hold to the dam thing!
It rattles alot less now at redline shifts, but its still there If it wasn't such a pain to get the other one off, I'd get it too...but it sucked getting it in, so I'm sure it'll suck getting it out. Just too lazy to deal with it right now!
Just my .05 worth
Old Oct 3, 2002 | 10:52 AM
Muckman's Avatar
Moderator in Chief
Default Re: whats up with the stick vibration on tegs ? (PatrickGSR94)
yeah i think its deffinately related to the direct linkage. You get a better connected feel but with that comes more vibration. I got a ton more when i installed a short shifter with poly bushings and an ITR ****. Mine vibrates even more now with my N1 exhaust.
Old Oct 3, 2002 | 01:30 PM
redacura's Avatar
Default Re: whats up with the stick vibration on tegs ? (Muckman)
yea.. the owner before mine took the linkage out and my shifter vibrator alot at higher speeds.. the dealer put one in for me for free.. about 20.00 if it wasn;t free... and doesn't vibrate no more...
from what i heard.. people take the linkage out for agressive shifting, with the linkage though u can feel the gears better... i liked the shifting though without the linkage...
Old Oct 3, 2002 | 02:36 PM
mugenracer's Avatar
Default Re: whats up with the stick vibration on tegs ? (redacura)
I've had two G3 integras and i've driven around 4/5 others and never noticed any vibration in any of them. Mine is a solid at high rpm as it is at idle/stopped!
Old Oct 3, 2002 | 02:43 PM
B_CRUZ!'s Avatar
WTF?
Old Oct 3, 2002 | 03:22 PM
Aaron M's Avatar
Default Re: whats up with the stick vibration on tegs ? (B_Cruz)
WTF?
lol, im lost to.
Old Oct 3, 2002 | 05:47 PM
Regular Series's Avatar
er...you kinda need the linkage in order to shift.
tgordenDELSOL
Aug 26, 2014 01:13 PM
BDM
Sep 24, 2009 02:16 AM
Benefitx
Jul 10, 2008 05:53 PM
slash00R
Nov 1, 2004 07:23 PM
Curtis2kul
12
Feb 13, 2004 10:59 AM
