89 ef si with b18 idle problem
okay so i bought an 89 si hatch off this kid with an idle problem.
the car idles between 2k and 25k rpm
the kid converted the wiring harness to obd1. but the engine is a frankenstein b18a1 block (obd0) with a 00 b18b1 (obd2) head. now theres a sensor right ontop of the intake manifold directly across the throttle body that is not being used because theres nothing to plug into it. theres no plug for it coming from the wire harness. i remember seeing this same sensor on my old ls swapped ek coupe. and when i removed it the car started idling when i plugged it back in it stopped.
i was thinkin that if i switched to an obd1 intake manifold it`ll eliminiate this issue. any other suggestions
What you are describing is where the MAP sensor is. Which intake do you have for sure? Maybe a picture would help. It could be the FITV (Fast Idle Thermo Valve) if it even has one. Have you checked the idle screw? Vacuum leaks? Is it running rich? Is the car converted to OBD-1? The more information you give us the better we can help you...
JDM_CAM23
Aug 10, 2011 06:13 PM
My_EFsedan
17
Apr 18, 2010 09:46 PM
