b16a head, gsr block, any obd conflicts?
Old Oct 3, 2002 | 07:32 AM
ricodemus's Avatar
Default b16a head, gsr block, any obd conflicts?
I would like to get a gsr block for my first gen b16 head that is non-obd. Does it matter if I get an obd1 or obd2 block? or will I have problems doing this in the first place? Can I run my stock ecu (I'm talking about sensors, not fuel)? Or should I use zdyne? I searched and found good info on the perfromance of this combe, but not any electrical issues.
Old Oct 3, 2002 | 09:16 AM
poison's Avatar
Default Re: b16a head, gsr block, any obd conflicts? (ricodemus)
nope, should run just fine. you will be able to use the same wiring and just plug it right up.
your ECU might throw an o2 code but highly doubt it...chipping it will solve the problem.
Old Oct 3, 2002 | 10:26 AM
ricodemus's Avatar
Default Re: b16a head, gsr block, any obd conflicts? (poison)
thanks. I am just a little unfamiliar with where and what sensors lie on the back of the motor. I was also wondering if the oil squirters mattered, since they are supposedly different in the first gen.
[Modified by ricodemus, 2:26 PM 10/3/2002]
4g4dcruisin
10
Sep 4, 2009 09:22 AM
peshte
19
Jun 15, 2005 09:55 AM
dt4life
14
May 25, 2004 04:44 PM
ASHY-ELBOW
Jul 23, 2003 09:12 AM
