Another accord EX window problem
I have a 96 ex and the drivers side front window rolls down fine but when it comes up it comes off track and sticks. I got to push it back in place to get it to go up. I replaced the regulator and lubed the slides but I still have the same problem. What else can I do?
Make sure the rubber run channel along the frame of the door is not pinched anywhere and you might lube the inside channel where the window slides with some silicone grease. I had a similar problem with my 90 accord, same window but the run channel had stuck to the window and started to bunch up near the rear view mirror. I made the mistake of removing the runchannel and it tore and so now my window rattles when its in any position except all the way up. I gotta hit the junkyard to see if I can find a replacement.
corkss
Nov 30, 2008 06:46 PM
Chief Brody
Jan 4, 2005 11:21 AM
