Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
SPAL FANS ♦ SPAL RELAYS ♦ SPAL MOUNTING SOLUTIONS
Old Aug 10, 2011 | 11:54 AM
SpeedFactoryRacing's Avatar
Default SPAL FANS ♦ SPAL RELAYS ♦ SPAL MOUNTING SOLUTIONS
Speedfactory Racing is your source for all SPAL USA components!
SPAL designs, produces and markets an extensive range of high performance electric axial cooling fans and centrifugal blowers for mobile and stationary equipment manufacturers throughout the world. We also manufacture and distribute a wide range of aftermarket products such as power door lock systems, vehicle security systems and power window systems.
Here are a few of the items that we use on a daily basis on our own cars and customer vehicles as well.
13" Curved Blade High Performance Fan / 12V Puller
VA13-AP70/LL-63A Fan (13" HP Curved Blade)
Our High Performance 13" fan line is the best of the best! It is our most popular primary fan for the street rod enthusiast. It is available in curved blade design for reduced noise and features a fully sealed waterproof/dustproof motor. Each fan is individually balanced for long life.
One of the most under rated items in your high performance engine build is a good radiator fan. Cooling the water/coolant running through the radiator is extremely important in every kind of racing. Maintaning the right temperature is much easier with a good, high-volume, electric fan. We are proud to recommend SPAL as our choice of fan.
SPAL 12" Curved Blade High Performance Fan / 12V Puller
VA10-AP70/LL-61A Fan (12" HP Curved Blade)
Our most popular fan design offers the highest performance on the market today. A street rodder's dream--high airflow for low clearance applications. It is used as a primary cooling fan for many makes and models of today's automobiles. The motor is fully sealed and waterproof/proofdustproof. Each fan is individually balanced for long life. A curved blade design is also available for reduced noise.
One of the most under rated item in your high performance engine build is a good radiator fan. Cooling the water/coolant running through the radiator is extremely important in every kind of racing. Maintaning the right temperature is much easier with a good, high-volume, electric fan. We are proud to recommend SPAL as our choice of fan.
SPAL 12" Straight Blade Low Profile Fan / 12V Puller
VA10-AP9/C-25A FAN (12")
From our low profile fan line this fan is ideal for oil cooler applications also popular in the motorcycle and ATV industry. It features a fully sealed waterproof/dustproof motor. Each fan is individually balanced for long life.
SPAL FAN RELAY HARNESS
Fan Relay Harness
Our fan relay wiring kits are a must-have when installing an electric fan. Safely integrates with OEM wiring and is also available in a 24V model.
FAN CUSHION BRACKET
Used for mounting the fan to your radiator, easy to use and very durable.
Please PM me for quotes on any of these items. Thank you.
Old Aug 10, 2011 | 06:43 PM
Woody.'s Avatar
Default Re: SPAL FANS ♦ SPAL RELAYS ♦ SPAL MOUNTING SOLUTIONS
I need a 13" and a 12"
Old Aug 11, 2011 | 12:13 PM
Thanks for the PM's guys. Keep them coming.
Old Aug 25, 2011 | 11:34 AM
Bump!
Old Aug 26, 2011 | 09:28 AM
Zer0_SpeedWorks's Avatar
Please pm best price for the 13in puller shipped to 91402
Old Aug 29, 2011 | 10:29 AM
Bump!
Old Sep 1, 2011 | 12:19 AM
recliner15's Avatar
13 in puller fits on a half civic rad? if not 12" and 13" shipped to 12547
Old Sep 28, 2011 | 09:17 PM
Bump!
Old Sep 30, 2011 | 04:44 AM
Charlie Moua's Avatar
what is the cfm rating on them?
Old Oct 1, 2011 | 10:06 PM
Old Oct 10, 2011 | 08:23 AM
Up!
Old Oct 13, 2011 | 09:22 AM
Keep it cool with SPAL!
Old Oct 27, 2011 | 08:58 AM
Bump!
Old Nov 18, 2011 | 12:10 PM
Up!
Old Nov 18, 2011 | 03:11 PM
julzrobz's Avatar
how much for the 12" curved? thanks!
Old Nov 26, 2011 | 12:00 PM
Bump!
Old Dec 1, 2011 | 11:18 AM
DEC 1st , wow this year has flown by!
Old Dec 15, 2011 | 11:38 AM
Bump!
Old Dec 15, 2011 | 11:39 AM
MikeyL513's Avatar
Pm price and cfm on 12in curved blade to 33776.
Old Jan 7, 2012 | 10:14 AM
Bump!
Old Mar 30, 2013 | 02:31 PM
Scott@SFR's Avatar
Bump!
Old Apr 3, 2013 | 01:20 PM
Scott@SFR's Avatar
Keep cool with Spal fans. Let us know if you need one!
Old Apr 5, 2013 | 07:02 AM
Scott@SFR's Avatar
TTT
Old Apr 6, 2013 | 03:57 PM
Scott@SFR's Avatar
Bump
Old Apr 7, 2013 | 02:21 AM
newtype_33's Avatar
pm'd
