coil pack going out - how to test them ?
I have a few coil packs they are the tec TC-08A packs . I cant seem to find the ohm rating these are supposed to be at when testing with a multimeter .
Any help greatly appreciated !
thanks guys !
thanks guys !
ya they said they could only test the ICM ( Ignition Control Module )
i was looking to use a multimeter and do a ohm test on the coilpacks . thing is i dont know what they are all supposed to read at ?
maybe ill grab a working pack and test the ohm rating on it then goto nonworking one and test it
FYI, you can have an ignition coil that tests good and actually be bad. I replaced a ton of parts trying to figure it out, was the coil all along. I don't remember the ohms, but it was in spec so keep this in mind. It would misfire or not start when very cold outside.
eghatch9295
14
Oct 7, 2015 02:24 PM
aalb1
Aug 7, 2005 10:50 PM
