83 accord won't start
Old Aug 10, 2011 | 05:39 AM
treyfeezy's Avatar
Default 83 accord won't start
about a week ago my accord died on me it will crank but not start. We ruled out it being a fuel issue and it was getting spark but a weak spark. I went with the least expensive option first and changed the distributor cap and rotor. I changed the rotor first because they had to order the cap, it started as soon as I changed the rotor but I changed the cap anyways when it came in since the contacts weren't in the greatest shape on the old one. So that is all done this past Sunday drove fine Sunday evening and Monday morning on the way to work. Left work Monday it fired right up had to stop at a store on the way home and when I left it wouldn't start. I made sure none of the plug wires came loose everything there was fine, tried to jump it just in case the battery was weak still nothing. I spoke to a mechanic friend of mine, he said it could be the ignition coil so I changed that still nothing. Any ideas or help would be greatly appreciated.
Old Aug 10, 2011 | 06:03 AM
civickiller's Avatar
Default Re: 83 accord won't start
try something simple- wire brush all the grounds to ensure a good ground and check the fuses
Niosa5
Mar 30, 2013 09:43 AM
BBallz24
Feb 24, 2009 01:56 AM
nickmcpher
Aug 21, 2008 05:10 PM
digital_cowboy
Jul 7, 2007 06:37 PM
lilgreenlude93
Apr 7, 2004 10:20 PM
