apexi world tour....rattling like hell....help =)
Old Oct 3, 2002 | 07:07 AM
caslmenow's Avatar
Default apexi world tour/SPORT =))....rattling like hell....help =)
me and my frend both have the same cat back system... i have a test pipe and he has a cat con. still and both of our cars rattle underneath.normal..
stop the maddness
vince...
[Modified by caslmenow, 4:41 PM 10/3/2002]
Old Oct 3, 2002 | 07:13 AM
cre18's Avatar
Default Re: apexi world tour....rattling like hell....help =) (caslmenow)
sick ride caslmenow , don't know what your rattling could be from.. is your exhaust or pipe rubbing on anything?
Old Oct 3, 2002 | 07:20 AM
dwnthehatch's Avatar
Default Re: apexi world tour....rattling like hell....help =) (cre18)
I have a worldsport with no rattle. Make sure you have clearance around your gas tank. I had to adjust mine a little to keep it from rattling.
[Modified by dwnthehatch, 11:20 AM 10/3/2002]
Old Oct 3, 2002 | 07:22 AM
vtec69's Avatar
whats a world tour??? Do you mean world sport??
If you do ive never heard rattling problems with it-make sure everything is tightend and its not rubbing any exhaust heat shields
Old Oct 3, 2002 | 07:39 AM
caslmenow's Avatar
Default Re: apexi world tour....rattling like hell....help =) (vtec69)
EXCELLENTE!!
Old Oct 3, 2002 | 07:44 AM
BROOD's Avatar
Default Re: apexi world tour/SPORT =))....rattling like hell....help =) (caslmenow)
SLPR 95 Si with Apex-i WS and never a rattle to be heard from it.
Take a peek underneath. A rattle should produce some sort of rub on the piping, then you'll know where the problem is and can deal with it acordingly.
Seeming that the WS is a three part cat-back, I'd suggest careful tplacement while tightening the bolts. Worked for me.
[Modified by SLPR, 8:45 AM 10/3/2002]
Old Oct 3, 2002 | 09:05 AM
Mr. Thunderlips's Avatar
Did you cut your front bumper to get some sort of makeshift grille?
Old Oct 3, 2002 | 09:07 AM
2camsaam's Avatar
what kinda front bumper do you have?
Old Oct 3, 2002 | 09:38 AM
sean's Avatar
Default Re: apexi world tour/SPORT =))....rattling like hell....help =) (2CAMSAAM)
how does it sound with the test pipe? sorry for no help.
Old Oct 3, 2002 | 09:53 AM
HybridHatchC1's Avatar
Default Re: apexi world tour/SPORT =))....rattling like hell....help =) (sean)
check the gasket between the header and the cat that was my problem, that dnout gasket is makes all kinds of crazy noise if it is damaged
Old Oct 3, 2002 | 11:20 AM
deviant94ex's Avatar
New User
Default Re: apexi world tour/SPORT =))....rattling like hell....help =) (Civ-JDM)
my WS was rubbing against the gas tank when i first installed it. it was nothing that a little heat from a torch on the mouting arms wouldnt fix. it was really annoying for thse first two days though. since i adjusted the brackets, it has been perfect. also, same question as the other guy, how does it sound with the test-pipe. you should have a really good comparison now that you and your friend both have them - one with test pipe and one with cat conv. thanks for the info.
CHRIS
Old Oct 3, 2002 | 06:38 PM
caslmenow's Avatar
Default Re: apexi world tour/SPORT =))....rattling like hell....help =) (deviant94ex)
the test pipe makes it sound crazy......it pops! around 3500 RPM. my accord colored civic is a dx and some how i beat my friends ex .... dx = cat back / test pipe / intake /.......
...DX - no power options are dope!
(maybe less heavy...... anyone know the weight difference between dx.ex ... none right)
Old Oct 3, 2002 | 06:40 PM
-Gambit-'s Avatar
my friend has a world sport and it rattled so we jacked it up and took a looks and the piping was rudding on the shift links, so we had to unbolt the piping and flip it over, and that was that no more rattle
caslmenow's Avatar
Default Re: apexi world tour/SPORT =))....rattling like hell....help =) (ThunderLips)
huh.. the little black strip...
some *** hole backed up into me and a paint chip flaked off ....
dont have the money now to fix so some 2$ vinyl worked just nice....
..easy cheezy....
Old Oct 3, 2002 | 06:42 PM
92SiB18C1's Avatar
Default Re: apexi world tour/SPORT =))....rattling like hell....help =) (SLPR)
Can you give me the part number for the WS for 92 Si?
Old Oct 3, 2002 | 06:43 PM
caslmenow's Avatar
the side skirts and lip are off the newer civics......
ghetto installed.... it fit nice .... but there is an inch of extra space at each end of the lip.....side skirts fit just fine...... i guess they are more flared...
[Modified by caslmenow, 3:58 AM 10/4/2002]
Old Oct 13, 2002 | 04:34 PM
sirminder's Avatar
what kind of spoiler is that and how much u pay for it...... me is starting to likes for my car
Old Oct 13, 2002 | 04:40 PM
93SSPHatch's Avatar
Default Re: apexi world tour/SPORT =))....rattling like hell....help =) (sirminder)
I have rattling on my WS as well. I have the 92-95 SI catback exhaust on a 1993 CX. I only rattles when I let off the throttle at around 2000-3000 RPM. I jacked up the car, and I noticed that the piping comes really close to the heat shield. I think for some reason at around these RPM, the resonation from the piping causes the heat shield to vibrate.
Anyone else experienced this same problem? I have talked to several other people who have the WS for their hatches, and they all had the same problem. A solution would be nice! I don't think removing the heat shield is such a good idea; afterall, doesn't it protect the gas tank from heat?
Old Oct 13, 2002 | 05:30 PM
Black_eh2's Avatar
New User
Default Re: apexi world tour/SPORT =))....rattling like hell....help =) (93SSPHatch)
i like your car alot heheh rotas like the spoiler too looks good on and off.. go with some smoke ambers with spoon mirriors
BuiltCivic99
Jun 8, 2009 04:04 PM
TypeRPaul
May 11, 2004 01:39 PM
miksew
Nov 17, 2003 05:54 AM
BigZ88
33
Jun 26, 2003 02:40 PM
