4X100 to 4X114.3 Adapters
Hopefully this is the right section...
Looking for someone who has ran 4X100 to 4X114.3 wheel adapters.
Are their any issues ? Clearence issues ? any rubbing ?
If you have ran this setup please chime in. I found a set of wheels i wanna get
and before i buy them just wanted to get some feedback / cons / bads etc..
the wheels i found are 16x7 and their 4X114.3 and of course my 4door is 4X100
thank you
Pic for refrence :
ill take the pics down if need be
thank you
Pic for refrence :
There's nothing wrong with spacers as long as you use extended studs, if necessary, and if larger than a 3mm or 5mm spacer you should really heavily consider hub-centric spacers.
In fact, for any bolt pattern reconfiguration I would recommend hub-centric spacers. This is really something you should spend $200-300 on the spacers to ensure your car remains safe.
i use spacers on my 4x114 wheels. as long as theyre hubcentric spacers tat are bolt on youll be fine. as far as offset, i run 16x7 +50 with the space so effectively +25. I have had no rubbing issues and i just have the fenders rolled. no pull or crazy camber
get ichiba, theyve been used on the sun autos cyber evo and they track it hard..no prob. of course you gotta make sure you get some hubcentrics ones. its already bad enough most wheels are only lug centric, just get the right center bore to reduce the vibrations... and thatll get rid of your worries of anything shaking loose. make you got the right tq specs too, dont want your wheel falling off on the freeway
If your going to run spacers on a street car that's fine, but if you ever plan on hitting the track then do the proper conversion. Considering your willing to run the equivalent of extremely low off-sets I'm sure it's not tracked anyway..
Look around, I've seen adapters as thin as 15mm.
What's wrong with choosing authentic parts over cheap knock-offs?
lol, nothing "wrong" with it. i just dont see the point of buying super expensive wheels that dont even fit the car. then choosing to use adapters rather than making the proper conversion. which in turn makes the wheel not even fit properly (too low offset)
instead just buy wheels that fit, look similar and are way cheaper in price. (there is nothing wrong with the quality of rotas)
GO-FIGHT-KILL
Jun 5, 2007 04:28 AM
