d15 to d16 vtec help?????
Old Aug 9, 2011 | 06:12 PM
wennerjake's Avatar
Default d15 to d16 vtec help?????
Hi I have a stock d15 in my crx right now and I just bought a d16 vtec engine with wire harness(not cut) and a p28 ecu, out of a civic, it looks that it will bolt right up, but my problem is that my plugs don't match up to mine. What do I need to do, will I need a new harness or what??? Thanks jake
Old Aug 10, 2011 | 05:39 AM
dephtone's Avatar
Default Re: d15 to d16 vtec help?????
The engine harness from a d16z6 will not plug into your interior harness. Depending on if your CRX is a DX (Has a DPFI d15 in it) you will have to convert the car to MPFI, which takes about 6 wires or so to do, real easy. Just search for DPFI to MPFI there are tons of write ups on it.
You will also need to get a OBD-0 to OBD-1 ECU conversion harness and OBD-0 to OBD-1 distributor harness for the ECU and distributor to plug into each other and operate properly.
Old Aug 10, 2011 | 07:05 AM
crx_si-r's Avatar
yup. your going to need to use your stock engine harness from the car, always use a harness that matches the car, and modifiy it to work. if you are not wiring savy feel free to check out my sig. i can build you a harness.
komet 163
Oct 18, 2015 04:43 PM
avaldez
Jun 24, 2009 12:59 PM
psychadelicfreedom
Jul 2, 2005 11:22 PM
stevomc51284
May 3, 2005 04:42 AM
streetspeed607
Jun 11, 2004 09:29 AM
